Question about JVC CH-X1100 12-Disc CD Changer
Signal R-8 I have this disc changer and I can hook-up power to the car stereo, but the R-8 keeps coming up. How can I reset the cd player or changer?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Hold eject for more than 5 seconds on the changer
Posted on May 18, 2009
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
2007 ford taurus air bag light on after replacing stereo
The CD changer option is similar to the single-disc player. The CD changer has the ability to toggle between the stereo and the multi-disc changer. In the 2007 Ford Taurus, the CD changer is located either in the vehicle's trunk or in the center console and has a magazine that can hold up to six CDs.---------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
I PUT A DVD DISC IN MY CD PLAYER BY MISTAKE IN MY CAR PLAYER, IT WILL NOT REJECT. CAN YOU HELP?
Try the PIN button
all stereos have this if you press it you will reset the unit and it might spit it out
or just disconect the power
Dec 06, 2010 | Car Audio & Video
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
2003 c240 cd changer is stuck
Usually if you disconect the battery leave for few minuets and then reconect it it usually spits the cd out as the unit resets itself saves a few 100$ hope yhis works if notbthe mechanisem in the unit has gone you will have to strip the cd player down to get your cd back
Sep 27, 2017 | 2003 Mercedes-Benz C-Class
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
UCH6006 stereo cd changer (Jensen)
your red wire goes to your aux ignision and also your yellow as they are both power wires
May 04, 2008 | Jensen XCH6RF 6-Disc CD Changer
Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Feb 09, 2008 | Sony CDX-T69 6-Disc CD Changer
JVC CH-X1100 12-Disc CD Changer Logo
316 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
