Question about Dishwashers
Water not pumping into dishwasher
Even though the motor comes on when the washer is turned on, when water should be pumping into the appliance, nothing happens. Yesterday while investigating the problem I found standing water and black slimey mold under the filter screen
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Posted on Jan 07, 2009
What is wrong I am getting a E 1 error on my LG Dish washer?
This is the code for a water leak, though FAR more commonly it means that the main wash pump is faulty. (I have only ever once seen E1 after a leak, even though that is the design).
This happens as the pump impeller is no longer fastened to the motor shaft, dishwasher misreads this as a drop in pressure, as it would have if water was leaking.
A new wash pump is fairly cheap, less than $100.00 and LGs are excellent dishwashers. I recommend fixing.
Tip: To replace the wash motor, take off the side panels, then turn the whole dishwasher upside down and remove the base. It seems like a lot of effort at first, but makes the replacement simple.
May 22, 2014 | LG Dishwashers
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water...
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Aug 03, 2008 | Bosch Dishwashers
We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 13, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Wash cycle doesn't seem to work. bottom has water
Your gonna have to pull the dishwasher out and shut off the water line. Then disconnect the water hose and get you a bucket. Then turn on the water line to see if water comes out. If water comes out strong then your water supply line is good, which means your inlet port on the dishwasher is clogged or hard water has clogged the little holes in the dishwasher arms. Dishwashers are meant to leave a little water remaining at the bottom to keep the sensor from burning up.
Feb 16, 2010 | Dishwashers
Water will not drain. Do not know if its a drain
Drain out is done via the pump out motor. Is the pump out motor working? Check by deternining with a AC voltmeter to see if supply voltage is across the terminals in pump out mode. If voltage is present and motor does not spin - the motor is open circuit and must be replaced. Remove the 2 clamps and the 2 electrical push on terminals with the MAINS voltage disconnected. Is the outlet pipe not blocked or obstructed ?
Jan 19, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Detergent cube does not disolve
Either:
Good luck,
Vlad
Nov 12, 2009 | Ariston Technologies L63 Free-Standing...
Kenore Elite Dishwasher
Either:
Good luck,
Vlad
Sep 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
No water spraying in washer, and no error code
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
Good luck,
Vlad
Jun 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
224 people viewed this question
Top Dishwashers Experts
Owen Barnes
