Question about Acer Aspire 5500 5570-2609 Laptop
Acer aspire 5562 have no power and won't turn on
It won't turn on (power led is off) and won't charge the battery. I've checked the adapter, it was plugged in properly. The adapter seems to work fine (the power led in the adapter is on). I tried to open the case to see what's wrong inside and the cable in the power button is properly connected. I don't know how to open the whole case to the PCB part(i think it's called motherboard for computer), therefore i don't know whether the power supply in the motherboard is properly solder/connected in the adapter power outlet part or not. the board seems to be permanently stick to the case. any suggestion to my problem?thanks in advanced.
  • 6 more comments
  • bbaalloonn
    bbaalloonn Jan 06, 2009
    thanks glmko, but the acer-solution.tk doesn't have the solution about the power supply problem.
  • Anonymous Feb 03, 2009
    my acer aspire 5570 is no power
  • whiteevan Feb 07, 2009
    i have the same problem with an acer aspire 5570
  • bbaalloonn
    bbaalloonn Feb 18, 2009
    @ cpenzes, thanks for your reply. The adaptor green light is on but the power LED in the laptop is off, no fan running, no battery charging, just a dead machine.
  • bbaalloonn
    bbaalloonn Feb 23, 2009
    I brought it to a local repair shop and paid for the test only because I refuse to change the motherboard, they said the components for power supply in motherboard is damaged or something like that. So I need to change the motherboard which is expensive.
    Anyone know how to repair this motherboard things? I wont mind soldering and messing around since my machine is already dead now
  • bbaalloonn
    bbaalloonn Feb 25, 2009
    @Comment posted on Feb 23, 2009: Which one is the "power supply itself"? How do I check which component is faulty?
  • bbaalloonn
    bbaalloonn Mar 01, 2009
    @Comment posted on Feb 25, 2009: I'm not going to take it back to repair shop. I''m going to buy multimeter and just test it out myself on semester break and see what happens.Thanks for the comments everyone.
  • DEKR
    DEKR May 11, 2010
    when did problem start and have you done any upgrades to system
    try moving adapter cord to see if maybe it's loose inside pc
    are you saying it does not turn on at all no fans running nothing
  • 167 Answers
What repair shop does work at no cost?? ok first check the voltage from the power adapter, if you have or can borrow a test meter. i have seen these go bad and still seem to work!( incorrect amperage and- or voltage). or you simply have a failed motherboard .good luck !
Posted on Feb 19, 2009
  • glenn hoffman
    glenn hoffman Feb 19, 2009
    also,these soldered parts can become separated from th board,I have seen this many times. getting at them is hard for people not familiar with taking apart notebooks . so be careful,as not to break anything else. again best of luck!
    Problem Solver:
  • 30 Answers
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 20, 2010
    Genius:
  • Acer Master
  • 1,102 Answers
That is probably your power supply to the system
if your not hearing any fans.
You can take it to a repair shop and they can test it for you most of them will test on the spot at no cost.
Please don't forget to rate
Posted on Feb 18, 2009
  • 1 more comment
  • DEKR
    DEKR Feb 23, 2009
    maybe get a second opinion
    cause personally think it may be the power supply itself not the components hard for me to tell when pc is not in front of me
  • DEKR
    DEKR Feb 25, 2009
    the power supply is where your pc components are all plugged in.
    Ofcourse a repair shop won't work for free but they will test the power for you.
  • DEKR
    DEKR Mar 02, 2009
    Okay let me know how it all works out
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Black screen and no power
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 11, 2012 | Acer Aspire 7736 Notebook
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
My acer aspire 5735z won't switch on.
Solution posted in your latest post,
http://www.fixya.com/support/t11566511-acer_aspire_5735z_doen_39_t_turn_just
Feb 03, 2012 | Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
I have an Acer Aspire 7736z which will neither turn on or charge. When I plug the power adapter into the laptop the LED light on the power brick turns off.
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Oct 24, 2010 | Acer Computers & Internet
Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Nov 19, 2009 | Acer Aspire 6920 Notebook PC
My laptop,acer aspire 5562, won't turn on(the power led is off) and won't charge. I've check the adapter is plug in properly.
As for the 5562 it sounds like the power supply may have gone bad. The output voltage and amps should be printed on it. Test it with a multimeter. As for the 5520-5865, did you discharge static electricity from yourself before you touched the memory? Apparently static electricity can damage RAM. Also make sure the memory is seated properly in the slot. I assume you had to remove a cover or something to install the memory. Maybe something got knocked loose when you were in there. Re-trace your steps.
Jan 06, 2009 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
342 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
