Question about LG LD65EL Dehumidifier
LG Dehumidifier Here is a strange problem! The dehumifier worked great for about a year and than went crazy. The unit will run for five minutes or so and then dies for a few seconds and then restarts. When it dies, the lights on the same circuit go almost out (dead short????)and then come back "on". The unit then runs for another 5 minutes and then repeats the cycle. I turned the humidstat so that the unit was always "on" to eliminate any question of the controls being screwed up. Still does it! When I first bought the unit, I had it plugged into a heavy duty (industrial- 20 amp) extension cord and one day the found the socket to be burned out. At the time I thought it was a problem with the cord so I changed it and had no further problem until now. Can this unit be saved? Fearing a fire, I have unplugged it.
  • 1 more comment
  • Anonymous Jul 24, 2008
    I had the exact same experience. The unit was extremely loud, so I'm not all that disappointed to be replacing it - with another brand, of course.
  • clinchma74 Aug 06, 2008
    I just bought a dehumidifier lhd65Ebly7 this weekend at Big Lots. I ran it for two days, and emptied the tank when the light said full. Today, I removed the tank before it was full and think I hit the full button doing it. When I replaced the tank the motor did not start. The display shows two bars on each but the motor does not start. I tried unpugging the unit and let it sit for a while to see if the circuit would reset but when I replugged it there was no change in response. IT LOOKS LIKE THE CONTROL CIRCUITS have failed. I tried to push all of the buttons (one at a time) to get a change on the display bu nothing happened. If there is a fix please e-mail me me. If there is none I will return it to Big Lots for a refund.
    Sincerely
    M.R. Clinch
  • Anonymous Oct 29, 2008
    Almost the same problem, My lights dim slightly only when the unit compressor starts back up which I think could be normal. I thought it might be in the electronics vs. the electrical.
    The unit will draw water out of the air ok, but it needs to be off for a while before it resets itself. maybe this is normal cycling to avoid freeze-up? I don't know. Sometimes starts consistently at the same HUmidity setting sometimes not
Had hot weather, worked fine, then turned cold , stoped running and just come on ever once while checked water no water in tank, lights are on what do you think is wrong got it on 35%, wated it to at least run the fan, because it cleans the air.
Posted on Oct 26, 2007
  • 883 Answers
The compressor motor is badly damaged...surprised it is turning on at all...the starting winding is bad, the running winding is fine...the motor is ...well done. new dehumidifier cheaper than fix
Posted on May 27, 2007
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
I have an ad50 dsr1 whirlpool dehumifier. Has been great for a couple years but now when turned on it instantly trips GFI. After further investigation I found the wires on top of the compressor are...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 02, 2011 | Whirlpool AD50DSL Dehumidifier
Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a LG LHD45 EL dehumifier, stopped working suddenly
Check the glass fuse on the circuit board inside the power supply at back of unit (have to take off cabinet)
Dec 03, 2009 | LG LHD45EL Dehumidifier
Ice build up
I would say you need a humid control on your unit.it may be running more then normal.
May 08, 2009 | Goldstar DH504EL Dehumidifier
Fan runs but no water, I suspect refrigerant leak, coils are clean, so is filter
My experiance when I ask my Heating and air conditioning guys when they were out serviceing my home air conditionion was a resounding NO not cost effective these units are practically considered throw away,with no value after 3-5 years no matter what price range and this is true. They say the cost is purchacing and adding the valve needed to refill. Just another prime example of total waste and disposable world we live in.
JTHOMEFIX
Sep 14, 2008 | Fedders A7DH45B2A Dehumidifier
Runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Apr 23, 2007 | Kenmore 54351 Dehumidifier
LG LD65EL Dehumidifier Logo
862 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
