Question about Dell W4201C 42 in. Plasma HDTV
Dell w4201C HD appears to be stuck in Dell Mode..
How do we clear that?
  • QualityE Jan 07, 2009
    It is just that the Dell is showing the Dell on the screen...It is as if it is stuck in Dell mode if that makes any sense..Can't find any info as to how to clear this mode...A lot of times you can use combinations of channel and volume buttons but we haven't found the right solution...Any ideas?
  • Dell Master
  • 19,396 Answers
The software image on the hard disk must be restored, this is done only at an authorized dell centre, or from Dell online, depending on the model.
The image disk is distributed only to authorized dell repair.
See:
Dell w4201C HD appears to be stuck in Dell Mode.. - secondary2.gifTroubleshooting secondary2.gifDrivers & Downloads secondary2.gifManuals
Posted on Jan 09, 2009
  • 837 Answers
Hate to be the bearer or "good" news
Read on
Posted on Jan 07, 2009
    Master:
  • 505 Answers
Turn of the HD TV. Unplug all the video cables. wait for 10-15 minutes to coll down. After 10-15 put the cables back. Turn on the TV. It should work fine.
If you still have the same problem, its a problem with the Digital processing board and needs to be repaired. Contact Dell at 1-800-WWW-DELL.
Thanks
  • 10,594 Answers
It looks firmware problem and requires Dell Support to update firmware or install new board.
  • 679 Answers
Please tell me some more about your problem.
I have a dell w4201c hd tv first got it used only the DELL logo comes on very clear purchased a main board and the tv came on worked perfect after 2 to 3 weeks turned on and picture comes in dim every...
Change input device to some other like a DVD player and see. Check for loose contacts in power outlet, RC cable, jack and socket. Try resorting to factory default settings. If nothing works, you may have to look for any dry solders, leaky/dry capacitors on board.
Aug 05, 2012 | Dell W2607C Television
My Dell W4201C high def tv will power on however a blank screen appears. only 3 years old. Saw samsung parts on the back, i just dont know what to replace.
http://www.retrevo.com/support/Dell-W4201C-TVs-manual/id/280ci052/t/2/
www.scribd.com/.../Samsung-Lcd-Lb350-650-Training-Book
Ok, have a look at these manuals especially the bottom one, this is a service and training manual, this has troubleshooting procedures.
May 11, 2010 | Televison & Video
DELL PLASMA
Most cases the Y-SUS, Y upper buffer, and Y lower buffer is the problem. The replace the 3 boards are located on the left side of the chassis when you open up the TV. 90% of the time this will solve the problem.
Look for burn marks on the upper and lower buffer boards (mostly around the chips with the heatsinks on them).
Apr 01, 2010 | Dell W4201C 42 in. Plasma HDTV
W4201C HD IS SHUTTING OFF BY ITSELF
From the web site that does sell boards, It doesn't seem to have the same parts.
Here's your TV parts:
http://www.shopjimmy.com/catalogsearch/result/?q=w4201c
And here's the W4200HD parts:
http://www.shopjimmy.com/catalogsearch/result/?q=w4200hd
I hope I answered you question.
Apr 29, 2009 | Dell W4201C 42 in. Plasma HDTV
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
I cannot change channels on my HD Dell plasma tv.
have u did a factory reset? menu, settings, fac reset, all settings, passcode 3355. try that
Jan 06, 2009 | Dell W4201C 42 in. Plasma HDTV
Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Jun 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell W4201C 42 in. Plasma HDTV Logo
66 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
