I have a whirlpool cabrio washer, wtw6600sw. How do I remove the agitator? The nut does not seem to come off?
The bolt is factory torqued. Unless you are bull strong, it will not move by simply wrenching it. Put a box end 7/16 wrench on the bolt head and persuade it by tap, tap, tapping on it with a hammer. It will take a few serious taps, but it will budge enough to turn it by hand.
Posted on Mar 14, 2010
Whirlpool Cabrio wtw6600sw2 top load washer is dumping water
Could you please describe the problem you are having a little better?
Dec 01, 2012 | Whirlpool WTW6600SW Top Load
F1 is displayed on washer wtw6600sw-wht
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Oct 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
    Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
    Manual and parts list click here.
    Hope this helps.
    Zeppelinx12
    Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    My Whirlpool Cabrio washer has some coins trapped in the inside of the machine. I need to find out how to remove the agitator to check inside for more coins.
    They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
    May 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Need to remove agitator to remove lodged medallion
    Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
    Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    My top load 4.5 cubic whirl pool cabrio washer does not seem to clean my clothes. it almost acts like there is not enough water
    your agitating belt might be slipping or worn, try holding the switch down with a pencil, and keeping the lid open and see if the agitator is moving or sluggish..good luck.
    Jul 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    CODE F 50
    most likely connection to motor sensor on bottom.. just behind the motor rotor the connection is probably not making good contact with sensor connection
    Jul 29, 2008 | Whirlpool WTW6600SW Top Load
    Washing Machines Logo
    141 people viewed this question
    Top Washing Machines Experts
