Question about Porter Cable 23GA Pin Nailer Kit
Nail gun will not shoot nails
I had a jam. I remove the pin nail and tryed to use and it still does not shoot any pin nails.
  • David Ford
    David Ford May 11, 2010
    can you provide the model number. Does the tool do anything like try to shoot? If it does I would look for another nail under the driver or possibly the driver might be bent. Make sure the driver is fully retracted. Let me know
  • 52 Answers
Remove the head, take out the blade and make sure its not bent or the tip broke off. Also while out insert the blade into the nose and see if there is any foreign object blocking the blade travel.
Posted on Jan 11, 2009
Hitachi troubleshooting
Since TV's don't shoot nails, I'm assuming your post is mis-matched somehow. Can you post again, with some more information and please specify what device you are asking about, a TV or a nail gun. Thanks.
Mar 30, 2014 | Televison & Video
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Ridgid coilnail gun jams and safty jams in place and gun will not fire. also somtimes will jam
if safety is jamming, its either bent or the pin that keeps it in place is missing/broken, you can find the pin right in front of the trigger. now as far as the nails jamming could be a few things. 1. wrong nails 2.right nail but may have gotten a defective batch 3. bucket that holds nails is adjusted to wrong size. 4.nails have been dropped/ squished and coil is not round anymore 5. nose is very worn and two nails are trying to come out at a time 6. driver is worn/broken and is trying to push out two nails at one time
Sep 18, 2012 | Ridgid Air Tools & Compressors
Dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Aug 19, 2012 | Dewalt Tools & Hardware - Others
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
My bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
Dec 03, 2009 | Tools & Hardware - Others
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Sep 24, 2008 | Hitachi NR83AA3 3 1/4" Clipped Head...
Porter Cable 23GA Pin Nailer Kit Logo
641 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
