Question about Canon FAX L-120 Plain Paper Laser
Can't send or receive fax
When you try to send a fax it gives me a message *Memory* Set Document.
Canon Fax/Hone 120
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Posted on Feb 11, 2009
Unable to remove on screen rec d in memory
Receiving Documents in Memory While Performing Another Task or When a Problem Occurs
If your fax is performing another task or encounters a problem when receiving a document, it
automatically stores the unprinted pages in memory, and the LCD displays MEMORY> as well as one or more messages. For an explanation of the message(s) and details
on the action to take, see page 64.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com Put CANON FAX JX200 as the subject and I will send it to you right away.
Oct 21, 2011 | Canon FAX-JX200
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Canon FAX L-120 does not send or receive
clear the memory or set it to not fax to memory. it should fax direct
Jul 26, 2010 | Canon FAX L-120 Plain Paper Laser
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Canon Laser Class 7000 - 'RECEIVED IN MEMORY' showing on display
Hello Tony,
You are right about that. The messages are indeed sitting in memory.Here's the procedure to print them out.
Step1: Press the memory reference button in the one touch speed dial panel
Step 2:Press the search keys(arrow keys under the one touch dialing panel)until the option "print document" is highlighted and then press SET.
Step 3:Press the search keys again to select the transaction ID of the document you wish to print and then press SET.
Step 4:Press # to print the whole document or * if you wish to print only the first page.
Jan 15, 2009 | Office Equipment & Supplies
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon L120 Fax machine
You have to make sure that the document release lever is fully down.
Jun 01, 2007 | Canon L120 Fax Laser Printer
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Canon FAX L-120 Plain Paper Laser Logo
233 people viewed this question
old marine
old marine
