Question about Sennheiser HDR 140 Consumer Headphones
Supplementary sennheiser hdR 140 headphones dont receive signal
The ones with the transmitter receive the signal BUT the supplementary ones just receive noise from the transmitter base.  What can I do?  Many thanks...
5 Suggested Answers
cardmechanic
  • 9 Answers
SOURCE: Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Posted on Jan 15, 2009
cardmechanic
  • 9 Answers
SOURCE: Bad battery
Battery Part Number: BA 151
Sennheiser Link:
  • 7 Answers
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Posted on Apr 02, 2009
SOURCE: sennheiser hdr 120 headphones no longer hold a
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Posted on Mar 06, 2010
SOURCE: my sennheiser hdr 130 has no sound even though it
This worked for me (this solution was posted on another thread). Unplug the base and take out the headset batteries. Wait 30 seconds. Reconnect. Turn on head set. I could hear immediately!
Posted on Jun 14, 2010
Why don't either the charging or on/off lights come on when my transmitter is plugged in?
Bad connections. Plug in and withdraw multiple times, It may serve to "clean" and polish the contacts. Hope it works.
Mar 27, 2015 | Sennheiser HDR 120 Consumer Headphones
Are there batteries in the headphone unit ?
Yes, there has to be or they wouldn't be able to receive the signal from the audio source.
Feb 19, 2015 | Sennheiser HDR 120 Wireless Headphone
Sennheiser HDR120 - missing transmitter / alternative OR replacement?
The system is working in the 860 Mhz range, so not that common. Most of the time it is cheaper to by a complete new system then to tray to buy components. Just keep looking in the thrift stores you find a transmitter for this headphone for a good price.
Jun 15, 2014 | Sennheiser HDR 130 Consumer Headphones
Left headphone not working
what is the source of the audio? I would start by checking that first. switch sources to see if the transmitter is the problem if the transmitter is only getting the right side signal, that's all you'll hear...hope this helps!
Jun 13, 2012 | Sennheiser HDR 120 Consumer Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
I feel that the 'normal' background hiss is a problem that I would like to minimize with the sennheiser IEM 300. I'm currently using the IE 4 ear phones. Would a different/better earset with maybe a...
No, that will not help. The his is a function of the receiver NOT receiving a signal from the transmitter as they apparently do NOT have a "squelch" circuit to mute the receiver noise when no signal is being received. The noise level when no signal is received is pretty high and apparently the volume control is not enough to reduce the hiss.
To solve this, LEAVE the transmitter ON and make yourself a switch at the receiver. DO this using one of those little in line lamp switches that fit on zip cord. Make one on a short length of zip cor with mating connectors to fit the received jack and the headphone plug. Don't worry about unshielded wire as the impedance is very low. Then you use this switch to mute the headphones when you want to. There are other switch types you can use, I am just suggesting what might be readily available to you.
Sennheiser SHOULD have include a mute switch on their unit as turning the power off on the receiver would be a pain. They could have used a volume control with switch to kill the audio line out... simple solution... oversight on their part.
Mar 25, 2011 | Sennheiser ew 300 IEM G3 In-Ear Wireless...
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Battery is: BA 151
Sennheiser Link:
Dec 24, 2008 | Sennheiser HDR-45 Consumer Headphones
Sennheiser HDR 140 Consumer Headphones Logo
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
