Question about HP OfficeJet 7310 All-In-One InkJet Printer
How do I use fax option
On officejet 7310 All-in-one , How do I set up and use the fax option
  • walker2c Jan 07, 2009
    Thanks for the solution, the analog cord was damaged. I am able to send fax, but have shared phone line with home, and are unable to receive fax. Is there a simple solution.
    Genius:
  • 2,120 Answers
Plug an analog phone line cord into the LINE port.
Posted on Jan 07, 2009
  • Leroy Elliott
    Leroy Elliott Jan 07, 2009
    Fax machines are designed to have their own dedicated phone line.
I have to either hit the start button or the menu button to recieve a fax. I'm not always home to do this. How can I get a fax without having to sit by it?
It sounds like you have the fax reception mode set for manual instead of automatic. Not sure on this model, but there is either an option in the setup menu for the printer or a button right on the control panel that changes this option. You want automatic mode turned on.
Mar 31, 2011 | HP OfficeJet 7310 All-In-One InkJet...
How do you set date and time on HP7210 printer?
Press: Setup, press: 4, press: ok, enter Date, then Time
Time is found in Basic Fax Settings option 4 and option 1 on the HP OfficeJet 7210 All-in-one series printer fax scanner
May 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My printer will not dial a number to fax sheet to.
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 17, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Auto reject faxes
Hi There
Simple answer No ! best way is to get your telco supplier to block the number that is spamming your fax m/c
Regards ~Al "alstech"
May 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How to set up fax number on my 7310 all-in-one.
According to the HP manual for this unit:
1. Verify that your HP all-in-one is set to answer fax calls automatically. (Press the Auto Answer button so the light is on.)
2. Press Setup.
3. Press 5, and then press 1.This displays the Advanced Fax Setup menu and then selects Answer Ring Pattern.
4. Press the down arrow key to highlight an option, and then press OK. When the phone rings with the ring pattern assigned to your fax phone line, the HP all-in-one answers the call and receives the fax.
You can download the manual from HP here if you've misplaced yours and need more setup information.
Apr 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Fax using a calling card
I use a calling card for long distance faxes. You don't have to "set" anything. They just mean listen to the printer. I am not at home right now to get the specific steps, but I believe all you do is put your fax stuff in the document feeder (I don't know if you can do this directly from the computer) and enter the 1-800 number from your calling card. Then the calling card will ask for your options and you will hear it from printer. That's what they mean by monitor. Then just follow the prompts.
Jan 30, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310 fax problem
Just change below settings
Press setup on the all in one. Navigate to Advanced Fax Setup using arrow key. Set the FAX Speed to Slow and turn off the ECM (Error Correction Mode). Try sending fax. Please simply send a fax (single page black and white text) (1-888-473-2963 . Check for the result.
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
