Question about Samsung L200 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
What do i do when my camara is frozen and the lens are stuck out
  • 4 more comments
  • Anonymous Apr 11, 2009
    I am having the same problem....except i never dropped mine? The lens is stuck out and wont go back in when I put it on charge it makes a funny noise then beeps 3 times and turns itself off!!?? GRRR Only had the poxy thing a week!!!
  • Neltharion Apr 14, 2009
    Mine is acting like this with something else. It started saying file error right as i was deleting some blurry pictures and whene i went out took another picture and went back in the entire camera just froze. It will not turn off or anything.
  • ncsmith1980 Apr 19, 2009
    My lens is stuck out as well. Nothing hapened to it, it's just stuck,and the camera wont take pictures or turn off. I tried doing the solution but it still wont work.
  • emmahutch Apr 28, 2009
    i have exactly the same problem except that mine is also out of focus- ive only had mine a week too! any advice?
  • Anonymous May 07, 2009
    My camera is frozen with the lense out. This is the first time ive ever had it happen.
  • poppyo1 May 24, 2009
    Recharging the battery with proper charger has not closed the lens in my case. Cannot take pics and there are no icons on screen. Lens stays out when battery removed (will not switch off on power button). When switched on lens pops in then gets stuck out again.
For lens stuck out/camera frozen, try power up with mem card out. Worked for me.
Posted on May 31, 2009
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Posted on Jan 25, 2009
Omg i've been searching for hours to find a solution to my stupid camera problem, granted my camera is the l730 but it worked! Thanks so much i thought i was going to have to buy a new one! :)
Posted on May 10, 2009
Conecte la camara al equipo y se quedo bloqueada conectar impresion el equipo no recnocio la usb pero la camara ya no se deja apagar ni prender quedo en pantalla negra y conectar impres
Hola desconozco si tu camara posee picture bridge,pero debes de revisar el setup y confirmar la configuracion USB mass storage debes seleccionar.De otra forma si esta seleccionado picture bridge o imprimir te va a solicitar la presencia de un impresora.
Saludos
Feb 26, 2011 | Samsung L200 Digital Camera
The Lens is stuck and the Camera (Samsung L200) will not stay on it turns off showing now picture.
maybe your camera had a problem on hardware.,try to pull the camera out if the display appeared.,the turn around of the gears malfunction,you can contacted the authorized service center for us to know if you need to replace the barrel assy part of the camera.,
Feb 22, 2011 | Samsung L200 Digital Camera
My lens seems to be stuck
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Jul 10, 2009 | Samsung L200 Digital Camera
My l200 camara lens is stuck
huSh now :( I remember my former camera.. XD
Lens errors are fairly common. Usually it's sand or grit interferingwith the lens extension mechanism. Or the camera's been dropped withthe lens extended. Or the camera has been powered on, but the lens hadbeen blocked preventing its extension. Or the battery ran down with thelens extended ...
Here's some things that you can do to try to correct it. They only seemto work for less than 50% of the lens errors, but if the camera is outof warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12...
hope this will help ya out
Jun 06, 2009 | Samsung L200 Digital Camera
Digital camara zoom
samsung digitmax d73 zoom lens will not retract, just pull lens outward gently it will click, then turn on camra ,you should be able to zoom now turn off camra lens should return & close
hope this helps
Oct 17, 2007 | Samsung Digimax S600 Digital Camera
Samsung L200 Digital Camera Logo
768 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
