I have a dell desktop htat i took the ram out of to try some free ram a friend gave to me. when i seen the ram wouldnt fit i reinstalled my ram i took out. i now get beeps and the monitor wont come on. when i click the monitor power button it goes green for a second and back to yellow.
  • 8 more comments
  • vengance Jan 06, 2009
    i tied that but to no avail. is it possible the cards (two 512 cards) went bad? i have reseated them a dozen times at a time and both together. i even switched the slots they were in. still nothng. i welcome any help. ..
    if im not mistaken its an ispiron 1100
    i apologize..its a dimension 1100 with windows xp
  • vengance Jan 09, 2009
    we can not get screen to power up it stays yellow... when we unplug monitor cable from tower it says no signal imput or plug is disconnected. when replugged up it goes back to yellow on power button to screen
  • vengance Jan 10, 2009
    ok friend it seems like u are speaking french ..but ill let u know how far i have got.
    1.i removed the ram and reseated it 15 times and its in right
    2.i remved the battery and left it out for 30 sec and replaced it
    3. i inplugged the lead thats supposed to reset the memory(i think its the right one) it has 2 rows of pins ..five on top and four on bottom. here is no extra pins to move the plug onto.
    when i plug the monitor jsut goes yellow. when i unplug says theres no signal input ..but the light goes green on my monitor. i need this resolved asap. my phone number is 1-276-565-1005. ask for jessie. maybe telling me as im looking inside the cover will help.
    I TRIED ANOTER MONITOR AND STILL SAME THING. IS IT POSSIBLE THAT SOMETHING HAPPENED TO BOTH RAM CARDS WHEN REINSTALLNG THEM (FRYING THEM OR SOMETHING)? ALSO I HAD HARDDRIVE REFORMATTED BACK TO FACTORY CLOSE TO A WEEK BEFOR THSI HAPPENED (paid dell techs to help me) and all was working fine tll removed the ram. my home number is 1-276-565-1005. maybe telling me what im lookin for over the phone will be easier. ask for jessie
  • vengance Jan 11, 2009
  • Anonymous Jan 12, 2009
    i reinstalled the os and had it working way befor thsi happened. i just tried 2 new sticks of ram and it does the same thing (inc, beeping) the os is xp. i cant install it agon becaus eit wont power the screen on for me to see, te power lighht to the monitor stas yellow.
  • errin durham
    errin durham May 11, 2010
    what type of dell is it?
  • 520 Answers
Are there 2 slots for ram do you have 1 mem card or 2
if you have one you have to make sure its in the right slot and seated properly.
if one check that its seated properly ....reboot
if nothing remove and reseat in other slot..reboot
Posted on Jan 06, 2009
  • 3 more comments
  • tat4u
    tat4u Jan 08, 2009
    try to boot regardless of what may or may not happen .if you see no response for a while press and hold down power button.remove power lead then remove battery for less than a minute.reinsert the battery and reconnect the power lead boot and try to access bios . in bios reset to default and exit..see if pc boots now ...before it will boot it will read mem and install to bios if all goes well.whilst youre in bios you might want to study if theres any method in bios that should be activated first.
  • tat4u
    tat4u Jan 09, 2009
    f*** me Ive only just noticed its a tower.Towers are a doddle.
    ok take off the cover to access mother board.
    remove vga (pci)from housing.(unless you use onboard vga)
    remove mem cards.
    remove rtc battery.rtc looks like a large digal watch battery.
    make sure you have your hd in first available connector on lead.if you have spare hd fit this on the second connector on same lead.
    this way bios will read first disk c: then 2nd d: then cd/dvd e: f: if another and so on...card readers,usb plug ins etc...
    re house vga(make sure tight and secure with retainer screw.
    re insert mem (if theres only 2 slots dont matter which order you put them.replace rtc.
    connect monitor lead and boot up.
    if the hd has not been reformatted yet due to probs you should now get a response at least to be able to reformat and install new os.
    if you have extra/spare hd this also can be formatted and either os can be installed or can be used for storage.
    if it seems progress was made replace cover.
    if you get to the format disk stage let me know for any details.
    if you still have prob I'll send you spotmau.
    but I think by removing rtc(to reset bios)when booted system should detect mem now and load it.
    anyway keep me posted...
  • tat4u
    tat4u Jan 11, 2009
    ok not so technical...
    remove cover...
    look at back of pc where the moniter plugs in..this is ur vga card...remove it...
    look on motherboard for a disk type battery (rtc) it maybe covered or in housing.its about the size of ur thumbnail...
    remove it about 1 min then replace...
    replace vga...
    boot up
    enter bios..( this is setup,screen shows which key to press to enter)
    in bios select default settings..
    save and exit..
    on bootup bios should detect mem
  • tat4u
    tat4u Jan 11, 2009
    if you have windows live messenger send me ur email so as I can locate you and we can talk on there for free.
  • tat4u
    tat4u Jan 12, 2009
    as far as Im aware youve formatted your hd(yes?)
    so being that theres no os installed is the reason why your monitor says no signal so dont worry about that for now .have you tried to install os (xp or vista?)
    if not try it it may kick the ram into action.
A Trojan virus can only be in your memory (RAM) if it's somewhere else on your hard drive. Your RAM loses all of the information its storing when the computer is shut off, it doesn't hold data the way a hard drive does. Back-up all of your info that you don't want to lose, and then reinstall Windows choosing the option to reformat the hard drive\partition and then install. You could try to run some free-ware virus programs on it before trying to reinstall Windows. I like AVAST Antivirus, Malwarebytes' Antimalware, & SuperAntiSpyware. There are some viruses and bugs that just can't be removed without reformatting your hard drive and reinstalling your operating system.
Aug 01, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Hi Good Morning....RAM is upgraded to 512MB ( 256
Ive seen a lot of Pentium 4 computers sell on ebay for less than $50 so no i wouldnt bother repairing. Cheers from Scott
Jul 13, 2010 | Dell OPTIPLEX PIII-450MHz 128MB 6.4GB...
I just installed a 1gb ddr2 ram in my system and even though it detected the ram , the windows restarts all by itself and the message appears saying windows wasn't able to start properly and the usual text...
you may have incompatible ram. You can try running Memtest on the application that will test the PC ablility to read and write to all the channel and sectors of memory. Also did you try both slots?
Jan 03, 2010 | Famous Brand Dell Optiplex GX280 Intel...
I need to reboot like factory setting from a computer a friend gave me. The problem is that we dont have the disc to reboot a 2350 dell. Can i do it without a disc>
Well, if the computer is not too old, and hasn't been messed with too much, Try this. When you turn on the computer, as soon as the dell logo goes away, you should see a blue bar across the top that says Hold down the RIGHT control key and hit F11 a few times. If all goes well, voila, Dell System Restore. This is the best way to do it, since it will reinstall all of the drivers and everything for you. HOWEVER this will erase EVERYTHING on your drive before reinstalling, so you will lose all of your data.
Apr 29, 2009 | Dell (2350-GV90W21) PC Desktop
Optiplex GX240 no high speed internet
Use an USB pen-drive or even a floppy disk because the drivers can fit in 1 MB.
Apr 21, 2009 | Dell OptiPlex GX240 PC Desktop
Plug the computer in and the light on the back and in the front
Try a different power supply or another thing you can remove the ram and reseat it
lety me know if this helps
Mar 14, 2009 | HP Pavilion a705w PC Desktop
Dell inspiron 2400 wont connect to the internet etc.
First You need to get the chipset driver, video driver to correct resolution and network drivers. Check in hardware manager which device need a driver and install it.
Mar 07, 2009 | Dell Dimension 2400 PC Desktop
Dimension 1100 desktop problem after reinstallin ram cards
you may have fried the original RAM by using improper installation techniques (no static provisions) or you may simply not be seating the modules properly, it take more force to put them back than you might realize. RAM is very specific to proper fit (voltages, etc.) Freebie RAM is rarely free.
Jan 06, 2009 | Dell Dimension 1100 PC Desktop
you could POTENTIALLY hook up an external hard drive and go into properties and change the Page File usage, however I would not recommend it. Page file acts like ram but it is extremely slow and usually not needed anyway
Apr 28, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
