Question about InFocus LP640 Projector Multimedia Projector
Lp640 infocus   1 red light blink - InFocus LP640 Projector Multimedia Projector
    Scholar:
  • 167 Answers
This means that the lamp didn't strike after five (5)
attempts. Unfortunately this can be caused by several different problems. Here are a few in order of most likely on down.
1) The lamp has failed
2) The molex connector that the lamp plugs into is loose and is not mating correctly with the connector on the lamp.
3) The lamp door (cover) is not fastened snug to the projector ie. the black screw that holds it is loose which can cause the safety interlock switch to close/open.
4) The ballast (lamp power supply) has failed and needs to be replaced.
Each of these problems can and will cause the the LED to blink once.
Good Luck.
Posted on Dec 29, 2009
  • 2,237 Answers
Lamp is not striking after 5 tries. try new lamp. if it still doesn'r work, you need to have the ballast replaced.
Posted on Jun 05, 2009
In Focus LP 640 won't even turn on? Any help
There are several reasons this could happen, and can usually be identified by glancing at the Power LED. The following applies to this particular projector:
1) Blinking RED led- Lamp or fan failure. Usually this is a bulb issue and simply needs the lamp replaced and the lamp life hours reset. Below you will find an image from the owners manual that will allow you to translate the # of times the LED blinks into a problem/solutionrobertsager.png
2) Solid Red LED means unidentifiable error. You will need to contact customer support at that point to schedule service.
Mar 07, 2011 | InFocus LP640 Multimedia Projector
Power button flashing and popping noise will not power up
If the LED is blinking red first make sure none of the vents are blocked, and are clear of dust.
If the problem still persists then your Lamp is has burned out and you must replace it.
Feb 27, 2011 | InFocus LP640 Projector Multimedia...
My InFocus LP640 Projector Multimedia Projector's light comes on but not splash screen appears. Just sits there
try reflashing the projector with current firmware, if that doesn't work, you nvram chip or main board is bad.
Aug 29, 2010 | InFocus LP640 Projector Multimedia...
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus sp5000 red led blinks once indicating lamp
be sure and reset the lamp hours. Flash the software if you can. These are also notorious for the ballast cable on the inside of the lamp housing backing out when a lamp is removed or replaced. If you have the cover off push the cables back into place and hold them there as you install the lamp. Also look directely at your lamp in the center and move it side to side and up and down. If there are any cracks or frosty looking spots or bubbles in the mirror of the lamp that are visible, then the lamp is probably shot. If all this fails, most likely it is the power supply, or the lamp door has gotten mishapen from heat and the actuator on the lamp door isn't making full contact with the safety swith.
Jan 29, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
It was running & just shut down. wont even power up ! nothing.I checked the cord & it's fine????
if a red led is blinking, it may have overheated. if there are no leds lit, you'll need to replace the power supply. you can get the part from an infocus service center and replace it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 02, 2010 | InFocus LP640 Multimedia Projector
How to disassemble an InFocus LP640
remove the top case, carefully unplug the ribbon cable from the main board, remove the 5 screws holding the board on, remove the 2 screws from the back (where the audio plugs are), and remove the 6 spacers from the vga/computer connectors. unplug all the plugs (be very careful unplugging the 3 ribbon cables in the middle. unlock the socket first by lifting up on the tab, then pull out the ribbon cables). remove the emi shield from the edge (metal clip with 5 fingers). remove the board!
Oct 30, 2009 | InFocus LP640 Multimedia Projector
I have infocus sp5000 and the lamp has stopped working. I pulled it our of the unit and it looks perfect. I suspect it is the lamp counter, but I need a method to reset without being able to see the...
there isn't one. you need to see the menu. but what color is the led and is it blinking?
green- all is well
red blinking:
1 time- lamp not striking after 5x.
2 times- lamp has more than 3000 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fan failure. shuts down.
5 times- undiagnosed error. possibly ballast or colorwheel.
if the colorwheel won't spin, the lamp won't light. when you turn on the projector, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
Aug 17, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP640 Projector Multimedia Projector Logo
217 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
