Question about JVC HR-XVC17S
Jvc hr-xv17 I need to get into the setup menu and I do not have a remote.I was given the dvd/vcr by a friend and have tried several universal remotes but nothing seems to work.
SOURCE: JVC HR-XVC1U DVD/VCR combo remote control problem
HRXVC1U Code Search
Posted on Jan 06, 2008
  • 472 Answers
SOURCE: JVC HR-XVC37U Combo problem
You have the child lock (CL) turned on.
Your instruction manual will have the information about turning it on or off.
It's purely t prevent small fingers doing bad things to expensive electrical equipment. =)
If you cannot locate the info in the manual, post back and I will hnt the relevant info for you.
Posted on Apr 29, 2008
This model is a DVD player not a DVD recorder. Only the VCR can record.
Posted on Oct 07, 2008
  • 1214 Answers
SOURCE: Need codes
Unit does not have a manual, but I did find this -
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Let me know if this works, and if not, I'll keep looking.
Posted on Feb 01, 2009
SOURCE: Can't get my new DVD/VCR to work.
I read the instruction manual one more time. It said to tune my TV to Video and voila, the VCR worked. All JVC VCR's seem to need the tv tuned to Video to play back. I had an older JVC VCR and I had to do the same thing with it.
Thanks anyway.
Posted on Jan 21, 2010
  • 639 Answers
SOURCE: I lost my JVC remote control model DR-MV79B, This
Each universal remote have certain code for each TV, read the manual for code, match the code with your JVC.
Posted on Feb 10, 2011
0 characters
1 Points
Without remote control
Try a universal remote and run through the auto and manual codes and hopefully you will be good to go.
Aug 30, 2014 | Sony RDR-VX560 DVD Recorder/VCR
I lost my JVC remote control model DR-MV79B, This is a some kind of combo DVD/VCR. I tried a rca universal but didi'work
Feb 10, 2011 | JVC DR-MV79B DVD Recorder/VCR
Remote control no longer works
buy a new one,,,(universal remote control)
Jan 30, 2010 | JVC HR-XV1 DVD Player/VCR
How do u change the time setting on the JVC HR-XVC-17
The clock is set using the menu.
Press setup menu button on the remote
Turn off the Auto clock setup
Select Clock
Use up/dn arrow to select and left/right arrow to set
Follow instructions to exit
Nov 02, 2009 | JVC HR-XVC17S
Volume is too low.
good day, not so familiar with this model but try this.
1) try to check in your DVD remote controller if it does have a + and - buttons indicating volume , if does have this features press + button to increase the sound output
2) if remote commander doesn't have this features try accessing the " SETUP" menu. most probably there would be a button in your dvd remote indicating this button "SETUP"
3)once you've access the setup menu, there would be a dialogue box indicating ( Video setup, Audio Setup, display setup, parental lock) insome cases it will show you a display picture of all this menu
navigate the dialogue box and look for "audio setup" once you've access this part there would be options and controls where you can change the volume/audio settings .
Jan 29, 2009 | JVC HR-XVC25U DVD Player/VCR
Setup Menu Unavailable for JVC HR-XVC30U
There were several screens that were unavailable and there seemed to be no obvious solution so I treated it like a PC and rebooted the unit. In terms of this unit, it meant unplugging the unit for an hour and then plugging it back in. All functionality is now available once again.
Nov 12, 2008 | JVC HR-XVC30U DVD Player/VCR
JVC HR-XVS44U - DVD tray won't eject
There are several capacitors in the power supply that fail and give this fault.
Sep 26, 2007 | JVC HR-XVC33U DVD Player/VCR
Top JVC DVD & Blu-Ray Players Experts
Are you a JVC DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
