Question about Mitsubishi WD-60735 Projection Television
Color wheel noise on Mitsubishi WD-60735
I have owned two DLP's to date and both have given me problems with the color wheel. I have tried several solutions to try to quick fix this. First I did a system reset and the noise was cut in half. Then I unplugged the set for two minutes, plugged it back in and held the guide and menu buttons down to run a self diagnostic. It found an issue with the color wheel, and self calibrated for the problem. The whinning is barely noticable now, but how long before it becomes unbearable again? I have a MASSIVE home theater with VERY HIGH decibles of ULTRA low freq bass. Could this be contributing to my color wheel problems? And could it be the cause of my unusually short bulb life?
  • zigmondsrh Jan 16, 2009
    I am having the exact same problem. Are you able to provide me with a bit more detail on how you did the self diagnostic test. I can't get my set to do it. Can you give me a step by step instruction? I would greatly appreciate it.
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
  • 184 Answers
SOURCE: mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Posted on Feb 14, 2009
  • 556 Answers
SOURCE: I have a Mitsubishi WD-60735 Television and after
Sounds like a bad color wheel.
Posted on Oct 23, 2009
Ecollier2012
  • 3459 Answers
SOURCE: double image mitsubishi wd-60735 have to cut tv
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 24, 2009
SOURCE: I think the color bulbs are going out. I called
Very common when you watch to much tv. Get your **** off the couch and go mow your neighbors lawn.
Posted on Dec 15, 2009
WD-60638 COLOR WHEEL PROBLEMS
Usually the wheel is not available except with a Light engine.
Aug 31, 2012 | Mitsubishi WD-60638 DLP TV
We just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
Aug 18, 2012 | Mitsubishi WD-60735 Projection Television
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Where is the color wheel on 60735
Color wheel if it has one is not sold by itself and the optical engine itself has to be replaced.
Mar 10, 2012 | Mitsubishi WD-60735 Projection Television
My Mitsubishi wd-30765 started to buzz. Then it made a squeeking noise. The indicator light went red. I changed the bulb but this did not help
WD-30765 ???
Please recheck model number as WD-30765 is incorrect/ invalid model number.
Buzz sound could be of bad color wheel in light engine and cause of problem.
Let me know correct model number to diagnose problem in your tv.
Thanks.
Dec 12, 2010 | Mitsubishi WD-60735 Projection Television
60" DLP
You have a Bad Color Wheel Assembly, have optics engine replaced.
Although these parts are seperate, Mitsubshi will not sell them that way.
But here is a site which might be able to help u in obtaining a new or factory refurbished Optics Engine.
Http://www.discount-merchant.com
Thank you:
Delhielectronics@live.com
Sep 28, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi Wd 60735 will not turn on
replace the color wheel p/n 938P137010 MODULE-COLOR-WHEEL
Aug 22, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
736 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
