My computer will not connect with remote desktop connection.
Well you sent via the internet
Posted on Jan 06, 2009
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
  1. Open Remote Desktop Connection
  2. Select the connection you wish to use with both displays
  3. Right-click and choose Edit
  4. Check the "Use all monitors" box at the bottom
Thanks
Aug 01, 2012 | Apple 24" iMac Desktop
Tip
How To Connect to home computer from Another Location
<p>Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as if you were actually sitting in front of your home computer.<br />Follow the given steps to configure your computer to connect with remote computers: <br />To use this feature, you will need to be logged into your computer with administrative rights. Make sure both computers are connected to the internet. <br />First you have to configure the host computer to allow users to connect to it remotely. On the host computer, right click on "My computer" and click on Properties option.<br />Under the Remote tab, select the option "Allow users to connect remotely to<b> </b>this computer" and click Ok button.<br />Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).Start--Run--type "CMD" then hit enter for command prompt.<br />Now make a connection on remote or client computer, click on Start button, go to All Programs&gt; Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.<br />Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer. If your username and password is correct then a remote desktop windows will appear. <br />
on Jul 11, 2011 | Computers & Internet
Tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 | Computers & Internet
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
How do I setup Remote Desktop Service
I assume that the the computer on which you want the Remote desktop and the target computer whose desktop you want to capture are networked properly and the IP address with other TCP/IP settings are properly configured.
That said Go to Start and click Run the Run box will appear. In the run box type "mstsc" command to connect. A box will pop up asking for the "Computer" enter the computer name or more preferably the IP address which you want to connect to and capture the desktop remotely the Target computer.
Go to the target computer physically and right click the "My Computer" icon and then in the menu select the properties tab and click it you will see "System Properties" window pop up. On the top you will see some tabs. Select and click the "Remote" tab. At the Remote Desktop make sure that the "Allow users to connect remotely to this computer" check mark is selected if it is not ticked tick it. This is the way you are allowing your computer and other computers on the network to connect to this target computer.
Now go back to your computer click the connect tab.It should always connect as long as you give the correct IP or computer name in the "Remote desktop connection" box.
Best of Luck!!!
Jul 30, 2010 | Microsoft Windows XP Professional for PC
Tip
Connect your home computer from Remote location.
You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
Follow the given steps to configure your computer to connect remote computer: To use this feature, you will need to be logged into your computer with administrative rights.
-To perform this task, first make sure your both computers are connected to the internet.
-First you have to configure the host computer that allows the users to connect it remotely. On the host computer, right click on "My computer" and click on Properties option.Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
-Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
-Now make a connection on remote or client computer, click on Start button, go to All Programs> Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
-If your username and password is correct then a remote desktop windows will appear.
Good luck.
on Apr 15, 2010 | Computers & Internet
Tip
How to Enable Windows 7 to make a Remote Desktop Connection
1. Go to Control Panel>System>Advanced System Settings
2. Go to Remote tab.
3. Under Remote Assistance, put a check mark on Allow Remote Assistance connections to this computer.
Note: This automatically adds Remote Desktop exception to Windows Firewall.
4. Click on Apply.
1. Go to Start>All Programs>Accessories>Remote Desktop Connection
2. Enter the Computer Name or IP address of the computer you wish to connect to.
3. Click on Connect.
4. For more connection options, click on Options
Here you can save the connection profile, adjust display properties, run specified programs upon connection, adjust connection bandwidth, etc.
For more information on specific tabs, click on Help.
on Mar 23, 2010 | Computers & Internet
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
Remote Desktop Connection on DI-704P
did you open TCP port 3389 on the router, and assign it to your computer? Remote desktop requires that port.
Mar 29, 2008 | D-Link DI-704P Router
Tip
How to connect your home computer from Remote location?
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
my_computer_properties.jpg Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
remote_desktop.gif Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
remote_dialogbox.jpg Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
remote_desktop_connection.jpg If your username and password is correct then a remote desktop windows will appear.
on Dec 03, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
