Question about Dehumidifiers
Dehumidifier wont turn on
I have a airforce dehumidifier and for some reaason it has stopped working, i got it for xmas and it was fine then suddenly it stopped working.It no longer switchs on, i have replaced the fuse just incase it blew that but still does not switch on.Any help would be much appreciated
  • tesmah2001 Jan 09, 2009
    I have the same problem. Mine is a Goldair GD-2015 model. It was working fine and yesterday would turn on and then shut off even if the tank wasn't full. Now it won't turn on at all. This model has settings for the desired humidity (50%, 75% and continuous run) and the light for continuous run is flashing in a pattern that makes me think it is putting out a code but the user manual doesn't say anything about that problem.
  • dvillijg Mar 28, 2009
    Same problem. My unit is a Goldair GD-2015. Was working well and following an empty of the watertank the "Cont" light now flashes twice, then delay and same sequence starts again. The on light stays on but can't get unit to start. Any advice appreciated.
4 Suggested Answers
SOURCE: Danby DDR255 Dehumidifier
only works when on fan setting why i have a musty smell that I need to get rid of model ddr255 serial 0402040704525 help..
Posted on Oct 24, 2008
  • 43501 Answers
SOURCE: My Dehumidifier stops working and it doesn't turn on
Here is a tip that I wrote about that problem...
Posted on May 03, 2010
  • 4736 Answers
SOURCE: Had the dehumidifier about 7 years & it has worked
It may simply be a case of one of the following:
1. The humidity extraction level is set to high. If your unit has an LED readout, lower it to 32 to 35%.
2. Remove and check the air intake filter. It may be dirty or clogged. Clean the filter if necessary.
3. Obstructed air space. You must maintain a minimum of 12" of free air space around the entire unit, while in operation.
4. The ambient air temperature is to cold for the unit to function properly. This usually occurs in basement applications. Where the ambient air temp at floor level is colder the air temp at chest level. Dehumidifiers (Unless, it's a Low Temp Model) strain at temps between 40 & 60 degrees F. Place the unit up off the floor or a sturdy table, counter top, etc. that will handle the weight of the unit, plus a full bucket of water.
The above were simple solutions to simple problems. The more critical ones would involve reiar or replacement.
1. Low refrigerant gas. Compressor would need to recharged.
2. Humidi-stat Sensor has failed and needs to be replaced.
The recharging of the compressor cost wise, is not a big deal. Finding some who has the equipment to do it properly, may be a problem.
Replacing the sensor (if you can find one for a 7 year old dehumidifier) is more of a challenge cost wise and labor wise. In the end, it may be better to purchase a new energy efficient model that has a warranty and the option of purchasing an extended warrant. Which can be money well spent.
Hope this helped you to troubleshot and solve the problem. Please be kind enough to let me know. Thanks.
Posted on Jun 10, 2011
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
Why did my dehumidifier suddenly stop dehumidifying, fan works fine
check that the tank isn't full or the outlet hose is not blocked. Remove the filters and clean if required.
Jul 27, 2014 | Fedders A7DH45B2A Dehumidifier
B q dc20 airforce dehumidifier
I do not repair items, I am an engineer. Contact the manufacturer for a list of repair stations, many now do a flat rate.
Price one on the web and as a general rule if it is under $250 it is probably more cost effective to replace it.
Jan 25, 2014 | Dehumidifiers
Looking for a manual for a airforce dehumidifier no, bqwdh/816eah
Call the company look online they might have it or call the manufactor.
Dec 29, 2012 | Dehumidifiers
The motor seems fine, but it no longer collects water or helps the clothes dry. It is an Airforce model BQDD122FW. If it is the heater element, how much should it be to repair, roughly?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
Feb 20, 2011 | Dehumidifiers
My dehumidifier runs but never fills up. All of a sudden just stopped working.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Aug 10, 2010 | Whirlpool Dehumidifiers
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
I had the same problem and went for the s**t or bust option, worked for me.... The pipe that feeds water into the bucket had become 'silted' (clogged up and causing water to flood the floor) so I shoved a pencil up it and wiggled it about. Has been perfect ever since.
Nov 28, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
969 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Are you a Dehumidifier Expert? Answer questions, earn points and help others
