Question about RCA Pearl TH1102 MP3 Player
Won't come on
Was listening to it and it shut off and now won't come on changed the battery but still won't work.
  • 8,596 Answers
Make sure the hold/lock is not engaged. If it still does not come on, connect to PC and upgrade the firmware by going to:
-Tha Mp3 Doctor
Posted on Jan 07, 2009
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
Volvo xc90 radio won't work. reset battery and it works until you shut the car off and then it won't work again.
thers an issue with the convenient/assesory module--get car scanned with pro equipment not at a partsplace
Dec 06, 2012 | 2004 Volvo XC70
I changed my car battery, now my 2008 Nissan Altima key fob won't work
There is a special procedure involved in keying your fob to your car once the battery has been changed. You must lock and open the door with your key. Turn the ignition to "on"(not start) then push the fob's open and close button, then shut off ignition. This procedure is done everything the key battery is changed. Hope this can help you!
Motorcycle Diagnostic Scanner
Oct 31, 2012 | Cars & Trucks
97 honda accord lx keeps dying and won't stay on. I replaced the battery, alternator and starter. It turned on but just stayed on till it drained the battery. what could it be?
have someone turn the key while you listen for the fuel pump to come on in the fuel tank. it should only come on for a few seconds if not than your fuel pump is bad.
Oct 02, 2012 | 1997 Honda Accord
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
What would cause 2.7 motor to shut down and won't
did the timing belt let go?sounds like it
May 12, 2012 | 2001 Chrysler Sebring
Shure slx1 won't shut off
You have probably locked the controls.
Jan 26, 2012 | Shure SLX1 Body-Pack Transmitter for...
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
When I turn off the ignition, shut the door, and lock my car the radio and main console lights won't go off for about 5 minutes. This is a new problem and everything I've tried won't get the...
is it a cavalier or sunfire in the door there is a dome light switch this allows you to listen to the radio or put thwindow up or down for 30 to 60 seconds sometimes the door switch shorts out on the drivers side you can test by taking the pass door switch and change for drivers door if not a short to body modual
Sep 14, 2011 | Chevrolet Equinox Cars & Trucks
RCA Pearl TH1102 MP3 Player Logo
49 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
