Question about Epson Perfection 4870 PRO Flatbed Scanner
Scanner not scanning
I have an Epson 4870 scanner. It will not scan and makes a clicking noise when it attempts to scan and a red blinking light comes on. It was working perfectly last week but now it seems jammed or something. Can you help me fix it?
  • Marjorie McGarva May 28, 2007
    I cannot thank you enough skymac...the lock was on inside the scanner, which I did not even notice was a problem. You are the best! I am so relieved not to have to return it to the vendor to be embarrassed over something I should have looked for. Again, many thanks. I hope I don't have to use you again, but if I do, I hope I remember that YOU are the one who hit the nail on the head...
    Marjorie
    You obviously don't know that much about scanners. The lid was locked; something I did not notice. However, thank you for attempting to help me through this problem.
    Marjorie
    Problem Solver:
  • 5 Answers
Your 'transportation locks' may have been engaged. (Check lower-left-hand-corner of the inside the scanner cover and the left-back side) See the manual: http://files.support.epson.com/htmldocs/pr48ph/pr48phrf/maint_3.htm
Posted on May 27, 2007
This solution was very useful. I had the same noise as described but the position of the tranportation lock was in the corrrect position. However I put it in the locked position and then back to the unlocked position and Bingo! the scanner started working again. So thank you very much for directing me to the possible problem. The transportation lock must have shifted slightly to cause the problem.
Regards Mike
Posted on Mar 08, 2008
    Genius:
  • 2,985 Answers
I guess there is nothing to fix maggi- unless these is a repair shop near by or a friend to take it to bits - but be warned I reckon you are into the next one.
  • john ash
    john ash May 28, 2007
    OOOh dear and it was only the other day we were
    asked the same question about a Canon
    Anh here I said - check the transportation locks
    Just goes to show you need three heads with this computing lark.
SOURCE:
When I try to scan one 4x5 positive sheet film it gives me 6 thumbnail pieces rather then one image?
Open Epson Scan and select Professional Mode. Turn off the Auto Thumbnail option which if it is not on the main page then check the small drop down menus next to the Scan/Preview options. Once that is off do a preview and the in the preview window manually draw a marquee around the area you need.
Feb 02, 2010 | Epson Perfection 4870 PHOTO Scanner
Hi, and thanks for your help. sad little noises on start up
Hello b3toed - sorry you're having problems; let's see what can be done.
First, there is a transportation lock on the scanner. (If you have a manual, it will tell you more about this.) Make sure it is unlocked.
Second, test the connection between the scanner and your computer -- make sure it's snug (well connected).
Third, if you were scanning a transparency just before this happened, make sure you've removed the reflective document mat.
After checking these things, turn it off - pause - then turn it back on. Best wishes for good results! -- ambssdor --
Jan 14, 2010 | Epson Perfection 2450 Photo Flatbed...
WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
Dec 24, 2009 | Epson Perfection V500 Flatbed Scanner
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
Grinding noise
The most common problem is that the pulley breaks, you might be able to see it through the glass. looks where the belt goes, and see if the pulley is broken.
also, some people forget to unlock the locking mechanism when the unit gets moved, the locking switch is on the side.
Apr 09, 2009 | Epson Office Equipment & Supplies
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
EPSON 350 scans 1/2 photo, makes loud clicking noise.
The chassis bends very easily on this model and the problem can be caused by scanner not being on a level base supported by all its feet.
Nov 04, 2008 | Epson Perfection V350 Flatbed Scanner
SCAN STOPS MIDWAY
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
Jun 12, 2008 | Epson Perfection 4990 Flatbed Scanner
Scanner won't scan full frame med format neg 2.25"x2.25"
ll you do is click on the arrow next to preview, and select normal instead of thumbnails. It took me a while to figure that out as well. Also, you will want to scan the film rightside up (opposite of what they say) and flip it in photoshop. When you scan it they way they say, the film touches the scanning bed, creating rings in your photos.
Dec 07, 2007 | Epson Perfection 4870 PRO Flatbed Scanner
4870 Photo Pro
Hi FYI, A lamp Circuit board and assembly would cost around 80% of the total cost of a brand new printer. Plus labor costs.
Sep 18, 2007 | Epson Perfection 4870 PRO Flatbed Scanner
Epson Perfection 4870 PRO Flatbed Scanner Logo
803 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
