Question about Insignia IS-LCDTV32 32 in. Television
Hello, Is there a way to fix image-sticking in a 32 inch LCD television? I was using it as a PC monitor, and now an outline of a program box I was using is stuck on my screen (several black lines, and faint outlines of words in the program). Can this be erased?
    Problem Solver:
  • 12 Answers
Since you were using it as a PC monitor anyway. Try Jay Screen Fix
Posted on Jan 08, 2009
    Novelist:
  • 140 Answers
Unfortunately, this is a very common problem with LCD televisions and some plasmas as well.
This is what the industry calls burn-in. That image is on your actual screen as opposed to it being caused by any other component in the tv. Really there is no convenient remedy short of replacing the actual LCD screen which can be done. Even by embedding another picture to lessen the effect of the burn-in would never restore the picture to its true quality. Good luck and God bless you.
Posted on Jan 06, 2009
Sony KLV-32S550A LCD TV double image.How to fix
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 21, 2016 | Sony KLV-32S550A 32 inch Multi-System LCD...
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
Aug 06, 2014 | Sceptre X322BV HD 32 inch Class Television...
I have a philips 32pf5531d 32 inch with 1 mdmi socket which i use from the tv to my sky hd box.What i want to do is cancel my sky so am wondering if i got just a broadband package without tv package i can...
If you have an hdmi output in the back of your tower pc then you can just plug this into your telly to get your pc images on your telly. If you have an older monitor with a different type of connection then you will not be able to connect your pc to your telly.
Hope this helps
Nov 22, 2013 | Philips 32PF5531D 32 in. LCD Television
I have a 32 inch ILo television and I am trying to program a RCA universal remote for it. I have the codes for the remote but can't seem to find instructions for how to program it. Could someone p
1. Find codes for each device and brand on
page numbers shown below.
2. Press and hold the TV, VCR1, VCR2•LD,
SAT•CABLE, or AUDIO button you want to
set up.
3. Enter the three digit code from the
TV, VCR, Laserdisc Player, Satellite Receiver,
Cable Box, or Audio code list.
Device Page
TV 11
VCR 12
LaserDisc Player 13
Satellite Receiver 13
Cable Box 13
Audio Equipment 14
4. Release the device key.
5. With the device on, press another button, for
example CHANNEL UP. If the device
responds, no further programming is
required. If the device does not respond,
repeat 2-4 using another code.
Aug 04, 2012 | iLO 3200 32 in. LCD Television
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
Big black image on the screen
You need to put it back in the box and return it. That is tearing.. The inner layer of your LCD screen is ripped. There is not fixing this.
Feb 15, 2009 | Westinghouse 25.5" Widescreen Flat Panel...
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Sep 16, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Insignia IS-LCDTV32 32 in. Television Logo
111 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
