Question about Hotpoint Ultima WF865 Front Load Washer
When trying to start all key blocked and it flashes (F-01)
When i try to start the machine by pressing start all the keys gets blocked and i cant change anything. and it starts flashing (F-01) constantley.
i have to turn it of from the mains to stop it flashing.
  • idealgraphic Jan 11, 2009
    thank you for your soloution
    i checked the motor, and it hasnt got brushes and i checked the pcb but there is no fault in the circut, but a friend said there can be fault with the software or the program,
    i dont know,
    can it be a different problem?
    l
    thank you for the reply.
    i guss i need to replace the pcb.
  • Hotpoint Master
  • 3,463 Answers
Error code F01 indicates a short circuit motor triac, this is part of the electronics that control the motor.
What you need to check first of all is the motor.
Remove back panel, undo 2 screws that secure motor, unplug motor lead, and lever motor backwards out of the brackets, don't let go of motor.
Check to see if motor has brushes fitted, if it has , check for shorted brushes and wear,if less than 2-3 mm, then replace.
If after replacing brushes and it still shows F01, then chances are it has blown the pcb, could be expensive, especially if you need to replace the motor.
If no brushes, then pcb is probably faulty.
Plz rate my solution
Thanks.
Posted on Jan 06, 2009
  • Barry Coates
    Barry Coates Jan 11, 2009
    F01 is as I stated previously a short circuit motor triac. it is part of electronics in the pcb.
    You will not neccesserily see any sign of a short
    or blown board.
Unable to print 46
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Sep 29, 2014 | Brother MultiFunction Center MFC-440CN...
My machine show a 01 and a flashing key I try to do hold a button for 5 sec to deactivate but time tab it's not reacting with at is the prob
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Mar 14, 2013 | Bosch Classixx WFL 2066 Front Load Washer
When I open my copy machine is a Sharp AR-M355U on the screen appears a message saying code H4-01 What should I do?
H4 error is heat roller under temperature, try pressing the "#" key then "Interrupt" key then "C" key then "Interrupt" key to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-outs on the fuser unit or the fuser lamp is blown.
Jun 21, 2011 | Sharp AR-M355U Copier
Jun 21, 2011 | Sharp AR-M350U Copier
How chang the time
To set date and time for Sharp UX 188 Press:FUNCTION then 3 then * * * * Display: DATE & TIME SET Press the START key: Enter two digits for the Month (01 through 12). Enter two digits for the Day (01 through 31). Enter four digits for the Year (EX: 1998). Enter two digits for the Hour (01 through 12). Enter two digits for the Minute (00 through 59). Press the " " key for A.M. or the "#" key for P.M. When finished, press: START key and STOP key
Mar 30, 2011 | Sharp UX 188 Thermal transfer Fax
My 01 chevy malibu theft deterrent light is on and my car wont start or let me get my key out of the ignition what can i do?
turn the key to the "acc" position. you will notice the theft light flashing. leave the key in this position for exactly 10 minutes. the light should stop flashing. turn the key back to the off position and then start the car as you normally would. Works every time!
Jan 11, 2010 | 2001 Chevrolet Malibu
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copystar cs-2550 service code c6000
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
Mar 30, 2009 | Copystar CS-2550 All-In-One Printer
I am trying to set time and date on a calculator
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
CMHIMG
Mar 04, 2009 | Canon P200-DHIII Calculator
Hotpoint Ultima WF865 Front Load Washer Logo
239 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
