Question about Sylvania DVR90VE DVD Recorder/VCR
DVD Recorder tells me it cannot record on disc
I have tried DVD-R and DVD-RW and both tells me that I cannot record on disc. I have recorded on DVD-R previously.
  • 1 more comment
  • Anonymous Feb 05, 2009
    Unable to record DVD after disc has been formatted. I have changed the disc several times without success.
  • johnston345 Feb 22, 2009
    I too get the disc error:
    Please eject the disc. Playback feature may not be available on this Disc. Yet I am using the exact same disc that has worked in the past which is the disc called for in the owners manual DVD-RW
  • Dirk Whittemore
    Dirk Whittemore Apr 03, 2009
    The problem shouldn't be the media. The machine calls for DVD-RW and I have recorded many DVD's on it. Now, I get an E4 error when I try to record, format, or undo finalize.
You can't use 16x or anything that says 1x-16x or 1x-4x.
The 4X speed DVD-R are difficult to find. (Tried Office Depot,OfficeMax, Staples, Microcenter,Best Buy and Walgreens!) Finally found Princo brand at checkoutstore.com
http://www.checkoutstore.com/Princo-4X-DVD-R-4-7GB-White-Top-p/prin4wt.htm
They worked great!
Posted on Aug 09, 2009
  • 86 Answers
The poblem is the media that you have. On some DV recorders you must use DVD+ to be able to record.
Posted on Jan 06, 2009
5 Suggested Answers
SOURCE: Emerson DVD Recorder EWR20V
The problem is likely that you are using 8x/2x media. Though the booklet does not say it, the burner does not support anything above 4x for DVD-R and 1x for DVD-RW. Calling their tech support can (possibly) get an update for this problem. Otherwise, the burner cannot use anything but outdated media.
Posted on Jun 02, 2007
eswaran73
SOURCE: Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Posted on Nov 08, 2008
SOURCE: cannot record on DVD-RW disc
I CHANGE DISK 4 TIMES WITH THE SAME RESULT
Posted on Dec 23, 2008
SOURCE: My recorder has stopped accepting NEW DVD-RW discs and ejects them.
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Posted on Feb 27, 2009
I have a Magnavox MRV700VR. I can record on a DVDR, but when I try to record on a DVDRW it tells me "disc error". Why?
It will be either that you have not formatted the disc or that you are using the wrong type of disc. You will need a DVD+RW on a + machine or DVD-RW on a - machine. Most recorders will playback the other type but not record on it.
Jan 28, 2013 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When attempting to record on a DVD-RAM disc the unit says that the disc is read only. This disc has been recorded on previously. Tried a new DVD-RAM disc with the same result
have you tried recording on a standare DVD disk, either DVD+R or RW or DVD-R/RW? if those don't work either, you have a bad recorder.
Mar 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Cannot record on DVD-RW disc
Somtimes if you change brands of dvds will help!
Dec 13, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
LVW 5104
check the disc maybe the recordable disc. some disc are written DVD+R/DVD-R/DVD+RW/DVD-RW. check if it is compatible with the recorder.
May 03, 2008 | Lite On LVW-5005 DVD Recorder
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Oct 27, 2007 | Sylvania DVR90VE DVD Recorder/VCR
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Sylvania DVR90VE DVD Recorder/VCR Logo
947 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
