Question about Emerson CF2600PW Raphael Pewter Ceiling Fan
Emerson Raphael ceiling fan does not work
I reset the wall switch so I guess the problem is with the ceiling receiver. The fan is up 30 ft so I would like to get the part. Any idea where to find it? Is it possible that a power surge burned it out? I hear that there are lot's of problems with the expensive piece of junk.
  • DZ Jan 07, 2009
    No -- I do not have have a solution but am not willing to pay $20 to get one. Thanks
  • 672 Answers
SOURCE: How do I get the switch code for an emerson ceiling fan?
There are switches in the remote and in the switch housing. Check this Emerson link for specific instructions. http://dl.owneriq.net/0/00837059-3b79-4074-8261-2ed4fed64384.pdf
Posted on Jul 01, 2009
SOURCE: Does anyone have an exact cross-reference for a
I disassembled the switch and determined that a Switchco catalog #A01 which is a Zing Ear #ZE-208S would solve the problem. The switch required must support OFF => ON L+1 => ON L+2 => ON L+3. The Home Depot switch appears to have contacts configured similar to Switchco catalog #A09. I replaced the Sabre PC-18 with the Switchco A01 model and it works fine now.
Posted on May 30, 2010
mcdevito75
  • 1970 Answers
SOURCE: Beeping sound in Emerson CF1 ceiling fan
mcdevito75 here, Are you sure it:s the fan makeing a beep or a smke alarm that needs a battery??.
Posted on Jul 27, 2010
  • 377 Answers
SOURCE: I HAVE A CEILING FAN
I have a Casablanca fan with a similar controller. In order to change direction on my fan I have to press the FAN and POWER buttons at the same time. I imagine they are not that different, so you might want to give it a try.
Posted on Sep 14, 2010
snowghost1
  • 784 Answers
SOURCE: just broke the glass light fixture on my emerson
you can find replacement glass at:
http://www.ceilingfan.com/Emerson_ceiling_fan_light.htm
or at:
www.emersonfans.com
c...
Posted on Feb 19, 2011
My ceiling fan and light does not respond to remote control any more. How do I get them to reconnect again?
Try removing power at the source, waiting a few minutes, and restoring power. Power outages cause the receiver to develop amnesia. In addition, if you try to restore correct operation by pulling chains or flipping wall switches, the receiver loses its tiny electronic mind. You may even find that the problem corrects itself at random over time.
May 15, 2016 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
I have an emerson ceiling fan with a light AND emerson SWQSRR controller.I can't figure out how the SWQSRR controller could control the fan and light seperately by only using 1 yellow wire?
Because it's a wall remote. Remotes will work fan & light with one hot wire. You should have a receiver in the canopy of the fan.
Oct 18, 2015 | Emerson Dryers
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
Can't reverse ceiling fan rotation
some fan models will only spin one way!! If there is not a switch on the side cover of fan.
Feb 04, 2010 | Emerson CF2600PW Raphael Pewter Ceiling...
Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Apr 28, 2009 | Emerson CF2600PW Raphael Pewter Ceiling...
HAMPTON BAY CEILING FAN MODEL # UC7067RC
I have a solution for you. Call 1-866-600-FANS(3267) and give them the numbers on the side of the receiver. Example: 7067FM-22 (6+5) Variations of this receiver are used by many different manufacturers including Hampton Bay,Emerson,Minka Aire, etc... There is a web site that shows a few examples of this receiver available. http://www.fanmanlighting.com
P.S. It helps to know if your Ceiling Fan has a 2nd light above the fan or reverses direction from the transmitter.
Aug 19, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Emerson CF2600PW Raphael Pewter Ceiling Fan Logo
47 people viewed this question
Top Emerson Dryers Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jim Thurston
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Dryer Expert? Answer questions, earn points and help others
