Question about Shinco DVD-833 DVD Player
Daenyx DV-833 (S/B) dvd/cd/picture CD Player
When I am watching a dvd movie I press the zoom button once till it shows 2x, unfortunately it stays on the whole time the movie is playing. When I press clear it only disappears for around 5 seconds. mind you that it also stays on the whole time for 3x and 4x also. The only time it doesn,t show is ofcourse when I leave the screen as is without touching the zoom button. On the 2x,3x and 4x there's a small arrow on the bottom left hand corner on the small box
How to zoom and remove the 2x off the screen
Using the remote control, locate the ZOOM button below number 7.
You can press this to zoom in on the picture (2x, 3x, 4x.. After 4x, if ZOOM is pressed again, the picture goes back to Normal)
There is no way to take off "2X" while it's in the 2x zoom
Jul 03, 2009 | Samsung DVD-1080P9 DVD Player
Daenyx dvd player suddenly won't turn on....no apparent reason
I have a daenyx dv-833b dvd player. the power button does not turn on when pressed. how can this be resolved?
Mar 22, 2009 | Televison & Video
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Zoom problem
The maker says it will go off by itself after 30 seconds.....If this is not the case see if there is a display button and turn display off,
I hope this is of help!
Jan 03, 2009 | Goodmans GCE5000 Portable DVD Player with...
Have a daenyx dv-833 dvd player
Good Morning,
Your connection is very easy so we should not have a problem isolating the problem.
We just have to go slow step by step.
First lets just check the Yellow cable just to be on the safe to side sure it is connected properly on the back of the DVD player and on the Televison.
Second, If the connectionn is secured. Turn the DVD player on, make sure you do not have a disc in the tray then turn the DVD player off.
Make sure the battery on the remote control is a fresh new battery (process of eliminattion).
Hold the remote control in front of the DVD front panel.
Turn the DVD player on with the remote control. Look on the front panel of the DVD player, it should read no disc. Press the Pro.Scan button "once". (Have you notice a flickering on the Television Screen).
If no flickering on the TV screen, press the Pro.Scan button again, ( this will be the second time). Have you notice the flickering?
If not, press the Pro.Scan button again ( third time). Have you notice a flickering on the TV screen?
Did you not notice on the LED of the DVD player if it read anything when you pressed the Pro.Scan button?
Try the above procedure again if your picture did not resume. If the picture resume in black and white, do not press the Pro.Scan button anymore.
Let me know the outcome up to this point.
Thanks,
Mike H.
Nov 02, 2008 | Televison & Video
Region Code Breaker
I have manage to play Region 2 DVDs on a the Region 1 that I purchased.
I starte by opening the tray and keyed in 98790. Initially this
didn't work. Following this I repeatidly pressed 9 until it came on, it soun
ds bizarre but it did the trick.
Regards.
Apr 28, 2008 | Televison & Video
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Aspire dvd player model #N820B
your remote control should have a button showing "display" that enables/disables on screen display
Oct 22, 2007 | Aspire Digital AD-900 DVD Player
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Shinco DVD-833 DVD Player Logo
188 people viewed this question
Top Shinco Televison & Video Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
