Question about Air Tools & Compressors
Air compressor flips breaker before it will start?
I have a craftsman semi lage roll around air compressor . It started to flip the breaker so I had a 20 amp installed just for it now it flips the breaker before it will even start. It will run a second sometimes then shut off or flip breaker.
  • 1,388 Answers
Air compressors tend to draw more power as they age, however, will not trip breaker unless some malfunction. Here are some simple tests. Unplug compressor and turn the pump by hand, you may have to remove a cover to do this. It should turn freely; any resistance could be failing bearing (would make noise) unloader/check valve leaking allowing back pressure to pump, or failed start capacitor/start winding. Easy test for checkvalve. With pressure in tank loosen discharge hose at tank and check for air leak. Check valve should hold pressure in tank. Replace as needed. Failed capacitor/s will cause high amp draw. Remove from circuit and test. UF reading should be within 95% of printed rating. Finally, most air compressor motors have two windings, start and run. Power to windings is controlled by flyball switch inside rear of motor. This switch has contacts that can stick in start position and cause high amp draw. Examine windings for signs of overheating. Copper windings generally have color of new penny. Very dark brown windings bad news. Gook luck
Posted on Jan 06, 2009
Air conditioner unit out side is not working. The fan is not moving, and it is flipping our breakers. The furnace is still running - so we are circulating the air in the house. The big unit out side goes...
it could be the compressor or possibly the dual stage capacitor that starts the compressor and runs the fan ,it will be marked with H-for compressor appx35uf./F-for fan at appx 5uf./ and a C-common terminal in the center for the neutral line to both fan and compressor
Jun 04, 2011 | Air Tools & Compressors
I have a roll air compresor its the weelbarrow type gas powerd wen i start it it fills up then it shuts off it will start again wen tanks are empty and the prosses has to be repited over an over
The pilot valve controls the pressure, idles the engine when set pressure is obtained and releases compressed air thru small vent while the engine is idling. If the idle is set too low, the engine may stall. Try increasing idle speed and make sure that when set pressure is reached that air is venting from pilot muffler vent. The pilot valve can be easily tested. With engine off and pressure in tank, flip the pilot valve start lever up then down. When flipped up, the throttle control shuld activate idle and the pull rope should be easy to pull. With lever down, throttle is pulled on engine and compressor is loaded making the rope very difficult to pull. If the engine stalls with air in the tank flip lever up to easily start engine then down to pump. Good holidays
Dec 19, 2010 | CRL 4hp Gas Powered Compressor
I have an 80 gal Craftsman air compressor who just shut down, the pressure is dropping, it made a smoke smell and it blew my circuit breaker. I tried starting my circuit breaker but it kept flipping off....
Usually related to the in-tank check valve. Follow the discharge hose from the pump to the tank. At the tank the hose attaches to a brass valve (or metal valve). This brass fitting is the check valve. It's purpose is to hold air in the tank and not allow the air to load the compressor when motor is trying to start. Easy to test. Use another compressor to pump air into your tank thru the quick disconnect or remove the safety valve and install hose there. Pump in about 75 psi and looks for leaks with soapy water. Remove air inlet hose from check valve and check for air leaks. If leaking, replace with generic valve available at or order from sears parts. If no leaks then suspect unloader is not working at the pressure switch. If both the unloader and check valve is ok then test capacitor for reading within 95% of rated valve. Good holidays
Dec 14, 2010 | Craftsman Air Tools & Compressors
Why is it my air compressor won't start after power fail until i shut the pressure switch off and turn back on
Hi my name is John. Welcome to FixYa. It will happen when you have a power surge, just flip the breaker in the breaker panel and it should be OK. Thanks for choosing FixYa....John
Nov 11, 2010 | Campbell Hausfeld 26 - Gallon Air...
Portable air compressor won't start
To be honest with you your compressor is what is commonly referred to as a throw away. You can't even imagine how many times I have posted that in the past month for your compressor and similar ones, such as the 3 gallon 1.5 hp craftsman.
The Porter Cable Is more reliable or rather it used to be. I believe that there are so many manufactures around the world pumping these things out that in order to get a reliable compressor you have to do it through the warranty. I know Senco makes a pretty good portable compressor. I believe Home Depot carries it and the cost is around $125.00.
That said your compressor may be salvageable so don't write to Santa just yet.
Almost all compressor,(even the throw a ways), come with a reset switch. The problem is finding it.
If you don't have your manual then start looking. You may need to remove the plastic shroud to locate it. All it is is a small black or red plastic button about a 1/4" in diameter.
Since you stated that there was a power outage that kind of rules out loose wiring or incorrect extension cord size. You may want to check the breaker though. You may have already but check it again. You want to turn it off and on a couple times to see or rather feel if the breaker itself has became compromised.
I hope something here helps.
Nov 17, 2009 | Air Tools & Compressors
6hp, 25 gallon compressor, never cycled back on, blew the breaker. reset the breaker and soon as i flip the compressor it trys to start then blows the breaker right away.
sounds like its the motor drawing too much current,has it got plenty or oil cause they run low and seize up,not the most reliable can be fine but equally can be dramas especially if its from China
Oct 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Central Air- Breaker flips when AC is turned on
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Air Tools & Compressors Logo
424 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
