XBOX 360 not connected to wireless connection on Linskys WAG54G2
We have Linskys wireless modem router with security of mac address filtering. The PSP, WII and laptop and DS all connected once I had entered the mac address in to the router, the Xbox 360 sees the SSID but fails to connect. I have tried wired ethernet but this fails on finding a IP address, I have moved the Xbox next to the router to eliminate any wireless distance issues, I have double checked the mac address is entered correctly. I used the mac address from the dashboard. I have tried port forwading still no joy. A friend tried the Xbox and wireless network connection at his place all worked find. Linksys say there modem is configured correctly, I am running out of ideas. Any assistance would be great.
  • kevin_herrin Jan 06, 2009
    Where would the wireless mac address be, I have used the one from the xbox360 dashboard and the one on the back of the wireless network adaptor?
    Genius:
  • 1,269 Answers
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Posted on Jan 06, 2009
SOURCE:
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
I just bought a Belkin wireless router for my internet to connect with my microsoft xbox 360 wireless adapter. the light turns on the adapter but it is a amber color and not red or green like always...
I've never heard of a Wireless Adapter turning amber or orange? This can be a simple light problem inside your Xbox 360. If it were fixed, the highest possibility is that color should be red. If so, this means the connection is not strong enough to your modem, and adapter. You will have move your Xbox 360 console closer to your wireless modem for the connection to be the best.
Dec 31, 2010 | Microsoft Xbox 360 Console
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
Attempting to connect WGT624 V4 as a wireless bridge to connect to my 2 wire qwest dsl modem to connect tv components to internet along with Xbox 360
To establish the bridge connection, make sure to write down the Wireless MAC Address of the 2wire first. Now login to your Netgear router's setup page and go to the wireless bridge settings. Manually type there the Wireless MAC Address of the two wire. Make sure to enter the same SSID, same Channel and same Wireless Security Key to successfully establish the wireless bridging. Save your settings after that and reboot the router.
Oct 22, 2009 | Computers & Internet
I have a cable modem with mediacom and a netgear g5608 router. i tried to hook up my computer, ps3, and xbox 360 but cannot get connected . whats the problem?
hi there! if your trying to hook up your cable modem to your netgear g5608 wireless router, First you need to clone the mac address of your network interface card to your wireless router in order the cable modem will communicate with the router. most cable modem reg the mac address of the nic of your computer.. Once your done of cloning the mac address to your router save the settings and turn off the computer, router and the cable modem.. turn on the cable modem first after 15secs then wait all the lights lit and turn on the router wait all the lights lit and the computer. your will notice that all your light is lit on the router and try to pull up the browser.. Now if you want to connect your ps3 and your xbox 360.. once your wired computer can access the internet, you will not have a problem connecting your wireless devices, you just need to setup your ps3 and xbox360 to connect and use the automatic ip address detect from your wireless devices.. you could either use static ip address and auto detect that your router will assign to your wireless devices.. if you still have any problem connecting your devices.. please feel free to call email me at dennis.ordinante@gmail.com or you can reach me at +09157222160.. good lick!!
Jul 17, 2009 | Computers & Internet
Similar problem restated: Xbox live won't work
why would you eneter the same mac adress as your pc?
Apr 08, 2009 | Microsoft Xbox 360 Console
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Need to add mac address to router form xbox 360 wireless connection
if its for the xbox then follow this:
. Navigate to the System area of the Xbox Dashboard.
2. Select Network Settings.
3. Select Edit Settings.
4. Select Additional Settings.
5. Select Advanced Settings.
The MAC address will be displayed toward the bottom of this page where it says Wired MAC Address.
hope it helps!
Nov 01, 2008 | Computers & Internet
NetGear WGT624 Wireless router
Check the security settings in the router . try 192.168.0.1 in your browser and check the access/security. Alternately reset the modem using button on back next to Ariel and press for 5 secs. Your computer firewall may be a problem or there may be an address conflict with your other modem.
Jun 28, 2008 | NetGear WGT624 Wireless Router
Open Questions:
AVIRA Antivirus TeCh SuPpOrT PhOnE NuMbEr+1[800]^246^7609 UsA AVIRA Antivirus Tech Support Number +1-8OO-246-76O9 to resolve all AVIRA products. AVIRA is an American multinational company which was founded by Michael AVIRA using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AVIRA Antivirus support number, and selling of computer-related services and products.AVIRA Antivirus TechSupport Phone Number Recently, AVIRA has been named the number AVIRA Antivirus technical supportadvice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AVIRA Antivirus customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Secrvice Requests, Chat, and Phone .Contact AVIRA Antivirus Support for Setup & Installation AVIRA Antivirus Wireless Setup Support & Installation AVIRA Antivirus Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for AVIRA Antivirus Connect, you'll be searching out AVIRA Antivirus Connect setup as well. So, here we're with all the setup process and recommendation for your to AVIRA Antivirus Connect. Get AVIRA Antivirus Setup Instant Support Phone Number and Customer Services
Jul 19, 2019 | Avira Computers & Internet
AVAST Antivirus TeCh SuPpOrT PhOnE NuMbEr+1[800]^246^7609 UsA AVAST Antivirus Tech Support Number +1-8OO-246-76O9 to resolve all AVAST products. AVAST is an American multinational company which was founded by Michael AVAST using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AVAST Antivirus support number, and selling of computer-related services and products.AVAST Antivirus TechSupport Phone Number Recently, AVAST has been named the number AVAST Antivirus technical supportadvice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AVAST Antivirus customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Secrvice Requests, Chat, and Phone .Contact AVAST Antivirus Support for Setup & Installation AVAST Antivirus Wireless Setup Support & Installation AVAST Antivirus Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for AVAST Antivirus Connect, you'll be searching out AVAST Antivirus Connect setup as well. So, here we're with all the setup process and recommendation for your to AVAST Antivirus Connect. Get AVAST Antivirus Setup Instant Support Phone Number and Customer Services
Jul 19, 2019 | Carrier Computers & Internet
PANDA Antivirus TeCh SuPpOrT PhOnE NuMbEr+1[800]^246^7609 UsA PANDA Antivirus Tech Support Number +1-8OO-246-76O9 to resolve all PANDA products. PANDA is an American multinational company which was founded by Michael PANDA using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, PANDA Antivirus support number, and selling of computer-related services and products.PANDA Antivirus TechSupport Phone Number Recently, PANDA has been named the number PANDA Antivirus technical supportadvice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, PANDA Antivirus customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Secrvice Requests, Chat, and Phone .Contact PANDA Antivirus Support for Setup & Installation PANDA Antivirus Wireless Setup Support & Installation PANDA Antivirus Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for PANDA Antivirus Connect, you'll be searching out PANDA Antivirus Connect setup as well. So, here we're with all the setup process and recommendation for your to PANDA Antivirus Connect. Get PANDA Antivirus Setup Instant Support Phone Number and Customer Services
Jul 19, 2019 | Panda Computers & Internet
KASPERSKY Antivirus TeCh SuPpOrT PhOnE NuMbEr+1[800]^246^7609 UsA KASPERSKY Antivirus Tech Support Number +1-8OO-246-76O9 to resolve all KASPERSKY products. KASPERSKY is an American multinational company which was founded by Michael KASPERSKY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, KASPERSKY Antivirus support number, and selling of computer-related services and products.KASPERSKY Antivirus TechSupport Phone Number Recently, KASPERSKY has been named the number KASPERSKY Antivirus technical supportadvice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, KASPERSKY Antivirus customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Secrvice Requests, Chat, and Phone .Contact KASPERSKY Antivirus Support for Setup & Installation KASPERSKY Antivirus Wireless Setup Support & Installation KASPERSKY Antivirus Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for KASPERSKY Antivirus Connect, you'll be searching out KASPERSKY Antivirus Connect setup as well. So, here we're with all the setup process and recommendation for your to KASPERSKY Antivirus Connect. Get KASPERSKY Antivirus Setup Instant Support Phone Number and Customer Services
Computers & Internet Logo
946 people viewed this question
Alun Cox
