Question about Microwave Ovens
ON CHRISTMAS AS I MIXED A CAKE MY KITCHENAID MIXER SOUNDED LIKE IT WAS STRUGGLING, THEN IT JUST STOPPED RUNNING. MY MIXER IS LESS THAN 5 YEARS OLD AND REALLY HASN'T BEEN USED VERY MUCH. PLEASE TELL ME WHAT MY RECOURSE IS.
  • 4 Answers
Is the warranty still valid?
Is there a recall on the model you have?
Typically the problem you describe is a problem with the motor brushes or you were mixing more material than the mixer was designed to mix and the internal thermal link failed.
The mixer is too young to develop this problem without abuse of a material flaw.
If there is no recall on it and the warranty has expired your best bet is to buy a new mixer. Repair cost will typically exceed the cost of a new on if it was a cheap model costing less than $50.00.
Posted on Jan 06, 2009
How to make a cake in koryo microwave oven KMC2323
Pinched this off the internet . Method Baking a Whole Cake in the Microwave.
  1. 1 Mix your cake batter. In a large bowl, combine 3/4 cup softened butter or margarine with 3/4 cup sugar and 2/3 cup flour. Stir together with a spoon or rubber spatula.
    • You can use regular flour if you don't have self-rising, but you cake will end up more like a brownie in texture.
  2. 2 Add in the rest of your ingredients. Pour in 3 tablespoons of milk. Crack in 3 medium eggs, and add 1 teaspoon of baking powder and 1 teaspoon of vanilla extract.
    • You can use whole, fat free, 2%, or whatever type of milk you prefer.
  3. 12Edit step 3 Flavor your cake. For a chocolate cake, add 1/3 cup cocoa powder. For a vanilla cake, add another teaspoon of vanilla extract.
  4. 13Edit step 4 Mix together. Stir well with a fork or use an electric mixer to mix for about 4-5 minutes or until smooth. If you have a food processor, you can also add all of your ingredients to the food processor for about 60 seconds to mix instead.
  5. 5 Spoon your cake batter into a microwave safe dish. This is very important! Never use a metal baking pan for microwave baking.
    • A shallow dish will probably give you the best results.
  6. 6 Bake your cake. Cook your cake in the microwave for 3-4 minutes on full power. The cake will bubble and puff in the microwave just as it would in the oven, and just as it starts to set (it'll still be jiggly), it's done.[2]
    • Check to see if your cake is baked by sticking a toothpick straight down into the center. Your toothpick should come out clean. If there is gooey cake reside on the toothpick, put your cake back in the microwave and cook it in 1 minute increments until done.
    • Take care not to overcook. If you microwave your cake for too long, it will dry out.
Sep 04, 2015 | In Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Kitchen Aid Mixer Model KSM5PSGR . I have had this mixer for about 15 years and recently while mixing dough, it started struggling to spin, and at some point stopped spinning. I just turned it on, and it...
it's possible the brushes on the motor are burned out. Are there 2 screw holes on the sides? You should have one on either side that look like a flathead screwdriver would fit in them? If so, inside those chambers are the brushes and springs for your motor. You can try replacing them. You should be able to order replacement brushes based on your model number(found on the bottom of your mixer). Let me know if that helps.
Jun 10, 2011 | Microwave Ovens
Have a 12 year old kitchenaid Superba stainless steel built in microwave. I suddenly stopped and "door' lights up on display. Door is shut hear clicking by left side may be a latch issue. How do you fix?
Hi - it is 12 yrs old so parts may not be available for it.
If its a door problem, then its really a door latch switch or switches that has failed. Time involved in removing case, then switches then checking them all then finding replacements at ?? cost is uneconomic.
Please consider getting a new machine - probably use less power, have more features and work a darn sight better than this old one.
Jun 08, 2010 | Microwave Ovens
Cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
I have a siemens combi micro oven, which is the best way to cook a christmas cake and at what temp
with the convection part at 325 deg, for 1 hour or less depending on the cake size..have fun cooking..
Nov 17, 2009 | Siemens HB77L55GB 900 Watts Convection /...
The electric dryer is about 10 years old. Came with house. It does not dry a load such as towels in less than 1.5 hrs. Typical with our previous GE was 30-40 minutes. Would a heating element be gone, dirt...
if it still gets hot its not the element your dryer vent could be stopped up not allowing air flow if its not getting hot the element is easy to change pull the back off after unplugging the dryer the wires easily unplug and take off screws you can get the part number from your local dealer with the model and serial numbers
Apr 07, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
