Question about Gateway Computers & Internet
Computer keeps turning off when I turn it on and then turns off if I leave it for a while.
  • 367 Answers
Look for the following setting. right click on the desktop (WINDOWS XP) select properties.
2.) Select screen saver
3.) Select Power
This will provide you with options for stopping your monitor from shutting down etc also from hibernating and going into sleep mode.
If you pc is overheating say the fan is not working this will also cause the computer to reboot. If that is the case you will have to replace the defective fan
Posted on Jan 06, 2009
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Acer aspire 5520 shut down after turned on for a few seconds
Hi Chritina,
I understand the frustration but this issue happens if the issue is with the hardware. It may be due to overheating of the computer, any hardware conflicts or malfunction, or may be due to Operating System corruption. Please try the below steps:
1. Keep on tapping F2 key on your computer keyboard as soon as you hit the power button.
2. Then press F9 key, press "Y" to confirm and then Press "F10" and press "Y" to confirm, the computer will restart.
It should take care of the issue, however, if the issue still persists, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the data on the computer.
However, if the issue still persists then the computer needs a Motherboard replacement, in that case you may need to contact Acer Technical support at 1 800 816 2237 and arrange a Depot Repair for the computer.
Thanks and regards,
Nov 20, 2011 | Acer Aspire 5520-5908 Notebook
Turn your computer off.
Turn the router off.
Use an Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your computer.
Turn the router on.
Turn your computer on, and let Windows start.
Click Start
Click Run
Type CMD
Press Enter
Press Enter
Look for output similar to: Default gateway ...
Start Internet Explorer
Press Enter
You will see the router's "login" screen.
Try several combinations of ID/password:
'admin'/(leave the password blank)
(leave the ID blank)/'admin' password
One of them should be correct.
Then, click to run the Wireless Network Setup Wizard to define your wireless network.
Aug 18, 2011 | Computers & Internet
In my gateway mx7120 the power button won't function. Can the computer be turned on any other way,?
Take the battery out and leave the machine connected to the AC power and try to turn it on. If it turns on then your battery is bad. There is a safety feature of LI-ion batteries, if the voltage drops too low, then the machine will not turn on to keep from over charging the battery and causing a fire. You may have to spring for a new battery in order to keep it portable.
Apr 19, 2011 | Gateway MX7120 Notebook
My aspire 5520 tries to turn it on, in kind of loop, without success. It keeps dark screen and there is no bios access available. The 'ON button' and the 'HD led', both keep 'on' for around 3 seconds,...
Hi, Every PC-Laptop has BIOS otherwise nothing would work at all. Try turning the PC on & hold down ALT & F4 together that should get you into the BIOS. As far as having no display then your Video card must be not working & needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 06, 2017 | Acer Aspire 5520-5156 Laptop
Why does my philips turn off when i use it as a monitor?
Probably you're using your tv as a computer monitor via vga input. just click on start,control panel, power option and select NEVER
Jun 20, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Can't remember how to turn off the power save function
The auto shutdown is designed to protect the tape and heads. If you want to use it as a web cam, just remove the tape.
Apr 03, 2009 | Canon ZR60 Mini DV Digital Camcorder
LCD Monitors
first use screen saver every 5mins this will protect your lcd from burn .
never use wallpaper with very high contrast same reason keep away from burn
its better to turn off you lcd monitor if your not using it. saves energy =)
Nov 12, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
when you plug it in to the usb cord charger, and then plug it out, it turns because it maybe does not have enough energy to keep it running to your standard. so, when plugging it into the computer, if charging, leave it plugged in, and too find out the amount of energy left in it, go to start, then my computer, left click on where it says sansa clip 2GB, and click propoerties, and it will state the amount of percent charged, then thats tell s you to keep it in longer
Jun 17, 2008 | SanDisk Sansa Clip MP3 Player
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
