Question about Sanyo DS31590 31" TV
The channel stays lit in the upper right corner
We lost the remote (use the DISH remote) to our TV and now the upper right corner always says "3" or "video" if we are playing a DVD.
Any suggestions on how to make this go away?
    Novelist:
    Scholar:
  • 67 Answers
Unfortunately, you almost always have to have the original remote control to get this display to go away. The "display" button is a specific code on that remote.
With Dish remotes, though, sometimes you can try different buttons and they will occasionally operate different functions. In TV mode, try the menu orother buttons to see if it makes a difference. My suggestion is to call a TV repair shop and see if they will allow you to borrow/buy an original remote for that TV.
Hope this helps you...
Posted on Jan 06, 2009
For dish when i use the control for one TV my other TV also changes to the same channel...how do i fix that?
It sounds like you are either in single mode on the receiver or Shared View. Look on the front of the receiver, you should have an amber and green light lite. The amber light should be lit under with 2 boxes. It is probably lit under the single box. Locate the Mode button on the front of the receiver (probably to the right front. Press the Mode button until you see the amber under the 2 boxes or the blue light comes on. When all 3 lights are lit, the receiver is in dual mode.
If you have any other problems, please let us know. Thanks.
Aug 07, 2011 | DISH Network EZ Remote Remote Control
Cannot get it to work with dish network. It won't accept channel input either!
Hello! If your tv just won't cycle to the correct channel you can change the setting if its tv1 you need a channel scan if it's tv2 try these steps:
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
DISH Network Customer Service
Dec 31, 2010 | Insignia IS-LCDTV32 32 in. Television
Have a722 reciver uhf remote will not change channels onlly have picture from tv 1
kristinjacqu,
Your 722 receiver may be in single mode. This is the case usually when you have the same picture on both TVs and the remote won't function. On the receiver when it's in single mode, you will have a green light for TV 1 and an amber light for mode under the single box.
To put in dual mode, open the door on the right side of the receiver (the door will open to the right). Once open, in the upper left corner of that area you have a mode button (to the right of the power button). Press the mode button and the amber light will now illuminate under the 2 boxes. The blue light for TV 2 should also illuminate indicating the receiver is now in dual mode. This will separate the 2 TVs and you can now watch different channels on both TVS, plus the remotes will now work. I hope this helps.
Ray Calo
DISH Network
Nov 25, 2010 | DISH Network IR Remote Control
Hi how can i get the codes to put in so i can controll my tv i have a philips universal remote but my tv is a symphonic i have lost my code book so i have no codes to put in pleas help
Hello Blue_down_4
Hope this helps you out.
SYMPHONIC..... 520 904 906 (codes)
Just incase you have forgot the process involved in setting it up. I'll talk you through it.
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the List I gave you above
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Cheers Little Dish Fitter.
Please leave a thumbs up if this helps you out.
Oct 09, 2009 | Philips Universal PH301S Remote Control
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I can't change channels,message on TV says,'' no input available''.
Have you tried reprogramming the Dish remote with the Sharp code? That might bring back the TV control. Another option is to use the TV's control panel menu button (if available), go to the setup choices and have the TV scan for channels while the Dish receiver is on. It will find channel 3 then, and probably nothing else, so the set will stay on that channel.
Mar 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Bright green 3 in the upper right corner of my TV
press the display button on your remote.hope this could help you.u
Aug 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Lost Instruction sheet for cl034
May 12, 2008 | Philips Magnavox Learning Universal Remote
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Televison & Video
Sanyo DS31590 31" TV Logo
204 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
