Question about Samsung RS2534 Side by Side Refrigerator
Samsung Ice Maker on Mdl RB215LASH
Ice Maker was turned off for about 8 weeks and was working when we turned off. Turned back on and ice tray has not filled , checked water supply input into their pipe and water is their. how do I trouble this problem
  • joe nelson May 27, 2007
    What does the motor have to do with the water entering the ice trays,could it be line input supply to tray is frozen, how would unfreeze input to trays without defrosting the frig
    Problem Solver:
  • 13 Answers
I have a Mdl RB2155BB and left the icemaker off for about 6 weeks. The solution to press the restart button caused the tray to dump, but did not refill. My refrig has a special water supply tube (you can recognize it by the braided stainless steel looking exterior) that has an automatic shutoff if there is a leak. I reset this tube by disconnecting it from the valve and then reconnecting it. Tried another ice maker reset and got water plus several pieces of ice. One more reset and all was fine. It seems that for this model Samsung
Posted on Dec 09, 2007
To all could never get a under samsung service to come out to house, went to Lowes where we bought it told them the problem, this unit was a year old, they said bring it back and we will give you full credit,so this was our solution, we bought a new GE from them and because of our problems with the samsung the discounted the new GE 15 % thas what I call standing behind the products you sell
Posted on Oct 13, 2007
There is a simple solution but maybe not for the long run.
There is a black rubber button on the front of the underside of the icemaker. It is a reset switch. I was told by Samsung support that this is a common problem if the icemaker has been off for a while.
Mine wouldn't work out of the box and several resets later it is still not making ice consistently. It has been 2 weeks and it has yet to fill the bin. We haven't used ANY ice from the maker. If the best it can manage between resets is a few trays... I think its time for a return to the store.
I hope you have better luck.
  • 883 Answers
The electric motor for the ice-maker is not turning...why? try disassembling and power motor with 115VAC cord from wall plug...be careful-ensure frig unplugged...using alligator clips...does it turn...can you hear it...it should turn VERY slowly.
Posted on May 27, 2007
Ice not falling out of ice tray. Why?
Is water going to ice maker? Is itaking ice at all
Apr 16, 2015 | Samsung RB215LASH
Water not getting to icemaker
This may be a temperature sensor problem on the ice maker. Check for broken wires or sensor fallen off.
Mar 24, 2013 | Samsung RB215LASH
Samsung RB215LASH freezer not cooling ice maker stopped working
Do you see any ice buildup on the back wall of the freezer?
Oct 18, 2012 | Samsung RB215LASH
Hello, I have an Samsung rs2533sw. the ice maker stopped working. it is at 8 degree. at this juncture, the manual reset switch does not work. if I let it unthaw then it works. once it gets cold it doesn't...
Hey heads up! The ice-cube maker has two parts... In fancy terms the business motor end, and the back-stop. Your back-stop is all busted. Mostly because it's been used successfully as a backstop for a few thousand times. The piece costs about $20, and you can get it at any Samsung parts distributor. The best way to check this is that your ice-cube tray will look like it's coming un-hinged in the back when it attempts to empty the ice.
When it works properly the ice-cube tray is actually contorted about 45 degrees from the front end to the back. The same way an adult male would crush ice.
Oct 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung ice maker tray won't reset
I had the same problem and would "temporarily" fix it by opening the front plastic cover (remove the 4 screws) and CAREFULLY remove the front - sometimes all the plastic gears will fly off but you can get them back because they only fit one way. Once the gears are off, you can reset the tray back to its fill position. Fit the gears back into place. Replace the front cover and it worked like a champ for a couple of weeks when I'd have to do it all over again. I finally got tired of it and ordered a new unit through ebay. Easy to replace BUT now the water won't come on to fill the tray!!!! UGH Hope this helps
Sep 21, 2009 | Samsung RB215LASH
Ice maker stopped working. Turned it off as there's no way I need a bin full off ice. I also don't use a lot of ice. Ice was "getting old" so I dumped it, cleaned the bin, turned the button on and nothing....
The freezer temp needs to be around 0 degrees for that "something" to click to tell it to dump and make more ice. Check the freezer temp and adjust if needed. If a thermometer says it's cold enough you may need that warranty you mentioned.
Jun 25, 2009 | Samsung RB215LASH
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Samsung RS2534 Side by Side Refrigerator Logo
479 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
