Question about Miele Revolution 600 Bagged Canister Vacuum
Miele Revolution Vaccuum cleaner manual
Is it possible to get a copy of the manual as I would like to know what the big black filter is inside the machine where the bag sits, which appears to be full of something like charcoal? A friend of mine says if you fit the hose in the hole above the filter and fit the little black gismo in the electrical hole where the three spade fittings are the machine should blow down the hose to clear any blockages. But what is the other spare filter which is empty but would fit in the same position as the charcoal filter? Very confused and in need of manual please if poss? many thanks Jane
    Scholar:
  • 95 Answers
Under the download section is the owners manual. This is for the same series Miele that you have so this manual will have most everything you need to know. The black filter is a charcoal filter, this is good if you want to control the odor but don't have allergies. If you have allergies you might wont to get a HEPA filter. I would recommend changing the filter every 6 months to a year. You need to use the empty filter when you want to use it as a blower. The hose will not fit into the opening with the HEPA or charcoal filter in place. I hope this helps.
https://www.centralvacuumstores.com/item.php?id=4545#
Posted on Jan 20, 2009
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
Miele revolution 5000 no power light flashing
I would refer to your owner's manual. If the manual has no resolution, then I would contact the manufacturer directly.
May 08, 2012 | Miele Vacuums
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
My vacuum (miele s251i) will not turn on. I just changed the filters and bag. Just wondering if I have put the top filter in the wrong spot. Does it go under the black flip-up bit or on top of it? I do not...
Hello Miller_04,
Regardless of how the filter is put in the vacuum cleaner should turn on. Really is no way to put the filter wrong in these. I have a white star myself.
You can contact Miele Vacuum support and they can further troubleshoot or recommend a vacuum shop in your area to send it to for repairs
Miele Dealer Locator (vacuums: non repair)
(800) 579-4583
Monday-Sunday: 24 hours Miele Dealer Locator (vacuums)
(888) 785-2828
Sep 16, 2009 | Miele S251i Plus Bagged Canister Vacuum
I have been given a SF-AAC 50 Miele filter which I was told fitted my Revolution 700 cleaner but I am very frustrated as I cant get it to fit please help
That is the wrong filter - the 50 series only fits Miele S4000 and S5000 models.
The filter you need for the 700 is the Miele SF-AAC-30
As seen here:
http://www.miele.co.uk/accessories/Details.aspx?rdid=5&aid=424
Jul 21, 2009 | Vacuums
Hi The catch on my miele revolution has come off
Not sure about this, but have had a look at my own Miele which is similar. I suspect that, although it may not be visible, something must have broken to allow that catch to come off. Sorry, but you probably need a professional repairer to actually take a look at it.
Jul 17, 2009 | Miele S548 Bagged Canister Vacuum
Hi Sally If you download the manual this will be easier to explain:
http://www.miele.co.uk/Resources/OperatingInstructions/S%20556%20S%20558%20S%20658.pdf
If you look at page 22 you'll see the optional blower attachment and how to install it - ignore this - however it gives you the view of the two hinges on the actual accessory door. These clip on at either side of the front but there should also be a square partition on the back of the accessory door. Here is where the clip sits into the door and the parts hook onto two spring holders at the bottom. Once that is fitted the door should then go onto the front.
Jul 17, 2009 | Vacuums
Ive got a miele revolution 5000 power plus and its just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=640910
Generic problem for all Vacuums
I’ve got a Miele revolution
Posted by rowler on Jun 02, 2008
I’ve got a Miele Revolution 5000 power plus and it’s just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not familiar with the light system on the Miele Revolution 5000 Power Plus
But it has something to do with the electronic hose assm or the circuitry in the vacuum itself. I have listed the factory phone # listed below for your further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/ Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Princeton, NJ 08540
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
I have a 7.2V Dust Buster Black and Decker cordless vaccuum and we have lost the little filter inside it. Where can I buy it?
I have a 7.2V Dust Buster Black and Decker cordless vacuum and we have lost the little filter inside it.
Where can I buy it?
Please include the brand name and model #
A lot of your local vacuum cleaner dealers carry the Black and Decker filters depending on the model #’s and I will post a few phone #’s listed below so you can order a filter. But 1st always check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://blackanddecker.com/
Contact Us -- Customer Service and Produce Support
1-800-544-6986 (M-F from 8am until 5pm, Eastern Time)
Black & Decker
101 Schilling Road
Hunt Valley, MD 21031 USA
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Miele S326i Vaccuum cleaner hose broke
any miele warranty center can help you with ordering a new part, look on line for close center. Or try main office.
Mar 13, 2008 | Vacuums
Miele Revolution 600 Bagged Canister Vacuum Logo
226 people viewed this question
Top Miele Vacuums Experts
Ryan S
Ryan S
Roger Potts
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
