Minolta EP 2010 copier, top loading doesn't pull paper
I have a Minolta EP 2010, it loads from the top and when you put papers in, they do not pull all the way through. Also, sometimes it jams alot, and there is a huge black line with a blank down the middle of the copy.
  • arandall Jan 07, 2009
    Actually, the problem with the paper not pulling all the way through is a BIGGER do I get it to pull through and copy straight from using the adf?
  • Office Equip... Master
  • 990 Answers
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Posted on Jan 07, 2009
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
My photo copier keeps saying pc ?
I worked on a EP 1030 copier and the error PC is when the machine doesn`t pickup paper. Make sure pickup roller is clean and there is paper in paper tray.
Mar 29, 2011 | Minolta EP1030/1030F CS/PRO Copier
Konica minolta EP-1031 PC code and toner install
Apr 16, 2010 | Office Equipment & Supplies
Power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Apr 10, 2010 | Minolta EP1030/1030F CS/PRO Copier
Epson stylus sx515w paper will not feed properly
pls make sure that you loaded the paper correctly.
Open the paper support and pull up the extensions. Open the output tray and pull out the extensions. Then flip up the paper stopper on the last extension, unless you’re printing on legal-size paper. . Flip the feeder guard up, out of the way, then squeeze the edge guide and slide it left. Insert paper, printable side up, against the right side and beneath the tab. Load paper short edge first, no matter which way your document faces.
Load letterhead or pre-printed paper top edge first.
Do not load paper with holes punched in it.
Do not load transparencies.
Do not load paper above the paper.4.3.4.jpg arrow on the edge guide.
Check the paper package for any additional loading instructions. 5. Slide the edge guide to the edge of the paper, but not too tightly. if you put the paper correctly and still not feeding the paper correctly, that means the rollers of the printer is broken
Feb 12, 2010 | Epson Office Equipment & Supplies
Online/error light is red
When you pull the paper out, that affect paper loading switch inside(or paper status monitering switch)
pull all the paper out, check switch inside near Loding roller
put you paper back and Put the tonner cartridge back, close the door and try agian ( i solved my problem this way)
Mar 25, 2009 | Samsung ML 2010 Laser Printer
If there is no light coming from the lamp in the scanner and the carriage is not moving this is a serious problem. It could be that the main board is bad. Typically the exposure lamp is just burnt out but if the carriage is not moving something more serious is not working. Just to verify open the document feeder on top and press the start key. You should get an error code if the lamp does not work.
Jan 19, 2009 | Minolta DI-2010F Copier
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
236 people viewed this question
