Question about InSTEP Schwinn Windrigger Rowing Machine
No reistance on the rowing handle.
After 2-3 pulls on the handle, and the fan speed increases, there seems to be no resistance until the fan slows down. The belt retracts but does not seem to catch until the fan slows down.
Blower motor works only on hight speed
Most heater fans have a resister built into the wiring and connection block on the actual casing. High fan speed=full voltage, Mid speed=small resister, Slow fan speed=large resister. Change the resister block. Pete
Sep 30, 2013 | 1998 Chevrolet Malibu
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
The windshield wipers on my 1994 S 300 mercedes diesel work intermittently then quit and start up again seems like they are ready to crash for good. how do i repair so they work when needed?
1) It is normal for the wipers, in rain sensor mode, to cycle once upon startup.
2) In rain sensor mode, the wipers should be intermittent with the cycles increasing as the volume of moisture increases on the windshield. The speed will increase until it reaches the continuous slow speed of position 2 on the switch. It will not increase to the fastest speed which is position 3 on the switch. You have to go to the fastest speed by manually rotating the switch to postion 3. Doesn't seem like a design flaw to me.
Dec 20, 2010 | 1994 Mercedes-Benz S-Class
Flashers stay on when riding but work at tickover.
your battery will be charged at a lower rate as the revs rise, you will need the final output rate to get an idea of what value the resister you will need to change it to, as a rule your indicator relay should be rate at 21w+ 21w now if your indicaters are flashing at higher flash rate then you will need to increase the resister rate and the opposite to make it speed up. what values you need will depend on what resister you already have , match it on a chart and then replace with next value until you get thew right flsh rate. as votage increases resistence increases.
Jul 12, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Intermittent blower speeds
pull motor ,check for burned wires onfan and bak of fan speed switch,fan could be the problem un hook fan and conect directley to 12 volts and see if varibles exsist,if so replace fan motor/look for a fan resister if all the other things check out
Jul 03, 2009 | 1999 Chevrolet Suburban
Fan wont work on 1 2 speed
sounds like either the spd. control resister or the spd control switch. The switch is what you handle, on the dash and the resister is on the blower box.
Jun 11, 2009 | 2002 Chevrolet Impala
Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
May 26, 2009 | Dryers
Squeak in concept 2 rowing machine bearing/fan
Try using some bicycle chain lube or WD40.
Dec 24, 2008 | Concept2 2 Rowing Machine
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
InSTEP Schwinn Windrigger Rowing Machine Logo
49 people viewed this question
Top InSTEP Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an InSTEP Exercise and Fitnes Expert? Answer questions, earn points and help others
