Question about Sony PFM-42V1 42 in. HD-Ready Plasma Television
Sony Tv PFM-42 V1 doesn't show any picture or tv menu
I have a plasma sony pfm-42 V1 , That turns on , the light changes green , But no picture , Or menu is shown , Does anyone know which board should i change ? thank you
  • 3 more comments
  • sherif807 Jan 06, 2009
    HI , Thank you so much for your answer, The tv has audio , But no picture at all .thank you
  • sherif807 Jan 08, 2009
    thank you so much for your help , I checked the service manual , I will try to see if i can buy the parts off of ebay . Thank you so much for your help
  • CASSADINE7 Jan 10, 2009
    I HAVE A SONY 42 INCH PLASMA TV , IT HAS GREAT SOUND BUT NO PICTURE THE SCREEN IS BLACK AND THE MENU WONT SHOW EATHER. WHAT CAN I DO?
  • psrivas Mar 28, 2009
    I have a sony plasma about 8 -9 years old.  We almost never used it and then we bought a dvd player and my son tried to hook it up.  The picture came up a for a few seconds and then something blew out.  What do you think happened.  can it be fixed and is it worth it to fix it up
  • Anonymous Apr 19, 2009
    any ideas????
    Novelist:
  • 140 Answers
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
Posted on Jan 06, 2009
  • roberto serbin Jan 07, 2009
    Without looking at the schematic or parts diagram I cannot give you part #s but I can tell you that in all the plasma tvs there are two boards called theY-sus(tainer) or Z-sus(tainer) boards that in less than technical terms are responsible for producing the picture on your screen. The two working together develop the pixels on your screen in whatever depths of colors they are processing. Regardless of the brand or model, most techs will first replace the Z board, but the best solution is to replace both. The reason for this is that the power supply supplies voltage to the Z-board directly, then a power cable goes from the Z-board to supply voltage to the Y-board. The technical reasoning goes that whatever caused the Z-board to fail weakened in some way components in the Y-board that will cause it to eventually fail. When you take the back cover off these boards will be one on the left side and the other on the right side with inputs going in to the plasma screen itself. They are clearly marked on the board itself and with some sort of white printed sticker. Let me say that either board can cause a no picture problem. I have never been the kind of technician to say replace both to cover your bases, but these problem cases are unique to plasma(s) and some Lcd(s). Each one of those boards are also identifiable by the fact that there is one IC that is heavily heat sunk to dissapate heat from the IC. That IC I can tell you from experience is the problem on the failing board, but is in a position that is not serviceable for the typical consumer. These IC's have a tendency to fail due to heat. The quiet cooling fans on your tv if there at all just do not cool them down enough. Many plasma(s) are failing after only a couple of years or so of service. This is one of the most common problems out there today and I hate to be the bearer of bad news but in the near future as well for those being sold as of this date. If you have problems getting a part # or place to buy either board let me know and I will help you. Good luck and may God bless you.
My sony pfm-42v1 no pictue
turn it off for around 30 min..try it again, then let us know what you find...could be a control board issue
Apr 27, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I have a Sony Plasma PFM-42 V1. When I turn it on
one of the electrolytic capacitor's are bad so one of the boards that control the TV are bad there is a good possibly its fixable but if you feel you don't want to I will buy the broken Tv from you so please email me at joekeniston@gmail.com
thank you
Jun 26, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
russell
Mar 08, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I have a sony pfm-42b1 plasma tv with 2 vga inputs an 1svideo input.. i want to connect my ps3 hdmi cable to the vga input. i purchased the cable but nothing shows.. thanks for your help
you should change it from hdmi to cable. You can do it only on a hdmi tv when you do that you can use it for the pfm-42b1e because i had the same problem too. when you plug your ps3 to a hdmi tv you go to settings-display settings- video output settings than you change it to av multi. After you do that you can use it on pfm-42b1e
Dec 16, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony Flat Panel tv with no Picture
Flat panel TV's typically do not have "bulbs," but rather backlighting.  Plasma displays are especially touchy during movement.  I would suggest checking your warranty status, as it's probably not something you can easily repair.  If you wanted to take on the repair yourself, be careful not to lay down the screen, as it will drastically shorten the life of the Plasma display.  I would start with checking the system boards for possible damage, since you did hear a "click," It was probably a fuse, chip, etc.
Oct 19, 2007 | Sony PFM-42X1N 42 in. HD-Ready Plasma...
Sony PFM-42V1N 42 in. EDTV-Ready Plasma
Yea the TV supports Pal 60
I had to use the bnc connection to AV. but yeah the tv supports Pal 60 you need to go into the menu and select it
just the colours arnt very good on this TV
Mar 04, 2007 | Sony PFM-42V1N 42 in. EDTV-Ready Plasma...
Sony PFM-42V1 42 in. HD-Ready Plasma Television Logo
553 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
