Question about RIM Blackberry 7100i
Black Berry Radio Problem
Every time i try to make a call the phone keep on saying "Time out Waiting on radio" even if its an emergency call and i have tried the trouble shoot solution that the manual provide which claim i should wait but the phone display the same message even when its hour after i restarted it
  • kliplyfe Jan 08, 2009
    dilshad raja thanks for you solution but im affaid it does not work
    if you can think of any other way to fix this problem please let me know
  • Tim Babcock
    Tim Babcock May 11, 2010
    Did you contact your cell phone provider about this?
  • 11 Answers
Have you tried hard reset.it might solve the issue.backup everything as it will go back to factory settings
  • From the home screen, select Options | Security Options
  • Select General Settings
  • On some devices, you now select "Services". If this isn't available, go to next step.
  • Click the trackwheel, and select Wipe Handheld
  • Click Continue
  • When prompted, type "blackberry" to continue
  • Your BlackBerry device will erase all the data and put the settings back to factory default
  • Posted on Jan 06, 2009
    I would like to order a handset to go with my phone KX-TGL432 what one goes with my phone?
    Hello Ella Rice...
    Go to Page 3 of your OWNERS MANUAL...
    In all cases (including your BASE UNIT),
    the wireless handset is listed as KX-TGLA40.
    Because I am a (twice) retired phone-man...
    I still insist on HARD WIRED base telephone
    (be somewhere in your house)...
    Bad things happen...
    and falling BACK to a
    cell-phone is a VERY poor EMERGENCY plan...!!
    Cell phone infra-structure is MORE FRAGILE
    than your BASIC TELEPHONE SERVICE...
    I'm just saying...!!
    (AND... I keep my AMATEUR radios working).
    ARES
    Radio Amateur Civil Emergency RACES
    Radio Amateur Civil Emergency Service RACES
    Carnac the Magnificent
    Nov 16, 2017 | Lands Phones
    My radio /cd player won't allow me to put the code in
    If the wrong code has been entered too many times the radio is likely to be permanently blocked.
    Each time a code is entered wrongly or the wrong code is used there will be a waiting time before the code can be tried again and each time that waiting time will be longer; up to several hours.
    It is important to enter the code and activate the radio precisely so check the procedure in the manual before starting then if the code won't go in assume you have the wrong code.
    The correct code can be purchased from the dealer or various internet sites offer "find your code" services. Alternatively it is possible to have the radio re-coded or decoded. Bear in mind the radio could be permanently blocked and effectively useless..
    Jan 24, 2016 | Cars & Trucks
    Cobra 18rv cb has 3 power wires, what is the yellow, (aux) wire for?
    The red lead (switched) turns the radio on when the ignition switch is turned on and off when the ignition switch is turned off. The orange wire is used to keep power constantly going to the radio so you don't lose the last channel you were on, and it gives you emergency weather information even if the radio is off. If you want the radio to stay on all the time even if the ignition switch is turned off then you can just put both wires to a constant power source like directly to the positive post of the battery or an un-switched connection on the fuse panel, and you just turn it off with the volume/power switch. But you have to remember to turn the radio off or you could drain the battery in a few days. So the choice is yours. :)
    Apr 17, 2014 | Cobra Radio Communications
    Pairing fail
    hi.i have work at a hyundai dealer during 6 years and your problem is the radio.the bluetooth module in radio must be replace under warranty.if you already remplace radio maybe its your phone but most of the time its the radio
    May 25, 2012 | 2010 Hyundai Santa Fe
    The stereo keeps saying "Err"
    The radio has to be left SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
    This can be many hours as the waiting time doubles after each wrong code.
    It must not be interrupted as the waiting time restarts if it is.
    Make sure you have the correct code
    I
    Mar 03, 2011 | Car Audio & Video
    Can this radio be used in the mountains for emergencies? What is the range of this unit? What channel should I use for an emergency?
    Channel 9 is the Emergency Channel for Citizen's Band radios. You'll probably have better luck tuning to a channel that you hear conversations being conducted on to get help though. If no conversations are heard, channel 9 is the place to go.
    This radio produces the FCC maximum allowed 4 watt output power with fully charged batteries. The effective range can vary from as little as 1 or 2 miles to 20 or more miles, based on elevation, antenna and surroundings. Of course, if you are in a desolate area, where other people with CB radios are 50 miles away - having even a whooping 45 mile range won't cut it. Plus, they have to have the radio on when you are calling, too. The flexible antenna provided on many CB walkie talkies is about "poorest excuse" for an antenna going. Consider purchasing a better antenna if you're going to rely on the CB for help.
    The same holds true for cell phones. If you're too far away from a tower to get service, people just 5 miles away won't know that you need help, unless you find them. What do you do? Have a back up plan. Call ahead. Is cell service available? Is your carrier (Verizon, ATT, etc. supported?) Are there government agencies that monitor specific radio frequencies? What other gear should you have before starting out? You should also arrange to leave a copy of your itinerary with someone. Set up predetermined times for contacting them - this way, should a contact time be missed, they will notice that you're missing and can take appropriate action.
    Be smart - be safe!
    Dec 22, 2010 | Maxon HCB-10C CB Radio
    Clarion pu 1570 radio cassette not responding
    If You know the code:
    1. Turn radio On
    2. Display say "Code in"
    3. Enter the Code by memory station buttons (4 digits)
    If You enter wrong code for the first time:
    1. Turn radio off.
    2. Turn radio on
    3. Press and hold the band "~" button
    4. Display shows ====
    5. Wait till display say "code in"
    6. Enter the code by mem. station buttons.(4 digits)
    Important:
    You mast wait by Radio ON in = = = = condition,
    and not in - - - -!
    The max. waiting time is 90 min.
    TIP:
    Tested by PU-1570A Eeprom 93C46
    1. Radio Off
    2. Press and hold the Band "~" Button.
    3. Turn the radio ON
    4. Enjoy!
    Apr 22, 2010 | Car Audio & Video
    My black berry keeps shutting its radio off regaurdless of its charge full or not and i have to turn the radi on every time to make a call that ends up being cut off and im not receiving texts .
    The OS on your phone could be corrupted....you can reflash the OS by using your Balckberry Desktop manager........going to the apploader and updating the software
    Jan 30, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
    Volvo radio locked on 'off' despite leaving it run for 1 hour
    take the battery posts off. by disconnecting the battery for a good 15 min you will wipe the residual memory on the computer then plug back in and try again. hope this helps
    Jun 27, 2009 | 2000 Volvo V70
    Computers & Internet Logo
    314 people viewed this question
    Top RIM Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    David
    Martin Murray
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
