Question about RCA D52W23 52" HDTV CRT TV
FL231 Concergenc Fuse blowing
I have a RCA D52W23 set. The Convergence went all wacky and I found on this site how to fix it by replacing the FL231 fuse. I replaced the fuse and about a week later it did the same thing. I have once again fixed the fuse and the TV is currently working correctly.
My question is, What is the cause of this fuse going out? Is there something else I should be looking at to find the cause of this fuse going bad?
Thanks
  • sphillips11 Jan 07, 2009
    How would I go about checking the ballast?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
Check the ballast. Also make sure that it is plugged into a GROUNDED surge protector!
Posted on Jan 06, 2009
  • Jody Sinex
    Jody Sinex Jan 08, 2009
    Any electric testing unit. The ballast controls the power supply to the light engine and bulb. It may be allowing surges through and popping the fuses. You could always pu a higher rated fuse in.
Convergence Issue
If you wish to get some details; visit the site linked here. Pull up older posts.
Aug 14, 2017 | RCA D52W23 52" HDTV CRT TV
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
How to replace a convergence fuse in my RCA Projection TV?
You will have to remove the deflection board on the left and resolder the transformer connections. That is the item with the red lead coming out of it. You will find bad solder joints around it. After that you will see 3 small brown rectangle fuses on the top side to the right of the transformer. I believe it's the middle one that is probably open. You should check them with a continuity tester or ohm meter if you have one. Replace the bad one and you should be ready to go.
Nov 18, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
No Convergence adjustment option in my RCA Projection TV
please check out the fl231 fuse poblem in the tips and trics under willtab profile you may have this simple repair
Jun 17, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Jan 02, 2009 | RCA D52W23 52" HDTV CRT TV
Rca hd52w59 3d screen colors are seroperated no convergence
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W23 52" HDTV CRT TV Logo
259 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
