Question about Linksys Wireless-G Broadband Router
My Linksky router is not working or I have it configured wrong
  • 1 more comment
  • Anonymous Jan 13, 2009
    I have the same problem. The setup disk runs, then tels me to remove it and reboot my computer because setup cannot be completed
  • Anonymous Jan 16, 2009
    how do i configure the router to windows vista
  • Ronnie van de Laar
    Ronnie van de Laar May 11, 2010
    How is it not working? I'd like somme more info on your problem. Do you get error messages?
    Regards,
    Ronnie
    Problem Solver:
  • 4 Answers
If u r using Linksky router, on vista machine with Ethernet cable the, first give a right click on LAN and check if it is enable then left click on diagnose, if u get a message windows could not find a problem try to connect, then try to use disc and configure the router or, try to configure manually please follow the steps: open IE type in address bar http://192.168.1.1
U/n= The default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Posted on Jan 28, 2009
I have Linksky WRT120N wireless. Trying to check security settings on line and I type in192.168.1.1 but this does not put me at the Linksky site.
This should take you to the webadmin page, leave the username blank and the password is admin, if this does not take you to the webadmin page you can verify your routers IP by opening the command prompt (control+r to open the run diaglog box then type 'cmd' and hit enter) and typing 'ipconfig /all' (without ' ' ) and looking at the value for 'default gateway' you may have to scroll up a bit to see it.
Aug 20, 2011 | Linksys Wireless-G Broadband Router
I am using a Belkin Wireless G Plus Router connected to my Virgin cable. I have had no problems with the router for 3 years however in the last month it stops working. To reconnect it needs powered off and...
From your explanation what i got is the router is not working and needs to be rebooted to start working. There is no changes done into the configuration.
In this case i suspect some software bug in the router.
I will recomend to backup your configuration and then reset once the router.
Remember if you reset the router the router will go to factory default settings and will loose all the configuration. you need to reconfigure that from the configuration backup you have taken recently.
Oct 31, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My belkin router says the internet is not connected when I connect the modem to it, but when I connect my modem directly to my computer it works. What is wrong?
the problem is that your router is not configured for your internet service...
click here to configure the router on your own...
select the appropriate tips and configure your router perfectly...
Any issues, comment me back...
Aug 02, 2010 | Belkin (F5D7230-4) Router (587009)
Using the Actiontec GT704WG as just a router with comcast's cable modem. Seem to have a configuration problem. I am not sure what I am doing wrong (connections, configurations, etc) Devices are recognizing...
The laptop/computer's wireless card may not have the latest wireless card driver installed or it is not enabled and working. Check Device Manager to see if is is working and enabled. I suggest you install the latest wireless card driver.
Next check the wireless card configuration, it needs to have the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 23, 2009 | Actiontec GT704WG Wireless Router...
BELKIN WIRELESS G+ NOTEBOOK CARD
Yes and No.
It will connect to a router using B (11Mbps) or G (54Mbps) mode.
It will not connect to a router using the new N (108Mbps) mode.
The best way is to set your router to "Mixed Mode", so it adjusts to the used network cards.
Feb 13, 2009 | Belkin 802.11g Wireless Desktop Network...
Vanguard 6455: double configuration.
when u reboot your router, at POST type ZAP command.. by this you will reset your password as well as your configuration.
try this and let me know ... wht happen??????
Jan 28, 2009 | Arris Vanguard 6455 Router
Cant get internet on ipod touch
This is what you do.... the yellow button on the far left of you router (the one with the bars and it says cisco systems on it) you hold that in until it it turn white or neon and blinking... then your network should be open and you do not need to connect! let me know if if works out.
Dec 28, 2008 | Linksys Wireless-G Broadband Router
I have the wireless g router loaded the softwhere it worked but now it say i have the wrong enquription
You have configured or changed your encryption settings on.your wireless card in your computer.
Go into the wireless router and check the encryption settings and then configure the wireless card in your computer exactly the same as the wireless router.
Dec 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
PS3 and my router
sometimes, you have to contact your service provider when you a wireless router such as linksky. they will then aask you which model link that you have and adjust your system accordingly. Your service provider can explain this to you.
Mar 10, 2008 | Linksys WRT300N Wireless Router
Linksys Wireless-G Broadband Router Logo
65 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
