Question about IBM ThinkPad 600X Notebook
Hello, I had a corrupt file windows\system32\c1252.ncs and it says I can fix it with orginal setup cd rom can you please assist ?
Wont start says windows\system32\config\system file is missing or corrupt and i dont have setup cd please help
Your Windows installation has been corrupted, therefore you need to repair the installation with the aid of an orginal Microsoft Windows CD. A Computer technician will be able to do this for you. Claim warranty support if you can.
Take care!
damnor01
Jul 13, 2011 | Computers & Internet
Do not have the orgiinal setup cd-rom let me type what it is telling windows could not start because the following file is missing or corrupt System32\drivers\Ntf.sys you can attempt to repair this...
hello
Try to restart and press hold F8 until screen is display and you can see lot of option there and select the last known good configuration and if it did not start you need to reinstall the operating or try repair it by inserting the Original cd installer of your operating system.
thanks
please rate
Apr 03, 2011 | Computers & Internet
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
I am having trouble running setup on my desktop
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
\Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Mar 22, 2009 | Acer Aspire One PC Notebook
I can't start my windows there is a error message
Well you need you windows XP CD to fix this problem. You have to boot to your Windows XP CD and repair the operating system. Any windows XP CD can be used to repair your computer. If there's none. Call the manufacturer of the computer and see if they can send you one.
Feb 10, 2009 | Microsoft Windows XP Professional
On my screen, I have "Windows could not start because the following file is missing or corrupt" Windown/System32/Config/System. You can attempt to repair this file by starting Windows Setup...
Try to boot in safe mode by pressing F8 while the system is booting.
Once in safe mode, use system restore to restore your computer state to an earlier date when this problem was not present.
Thanks
Aug 23, 2008 | Compaq Computers & Internet
It won't boot
Hello maybelle,
Your system is corrupted, files needed to boot up windows was corrupt or it was deleted accidentally, the only solution that can correct the problem is provide installation disc(windows installer) and insert it to the CD ROM and boot your system to CD DOM and follow the the on screen instruction.
(note: installation of Operating system can lost your important files, back up the files)
installation of OS refer to this info: http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
please do not rate me if the solution not solve the problem.
if need more info, please notify me, i will give you more information.
best regards.
Apr 09, 2008 | Toshiba Satellite M35X-S161 Notebook
IBM ThinkPad 600X Notebook Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
