Question about Toshiba W627 VCR
Tape stops playing after a few seconds....
The vcr doesn't power down or turn off..only the tape stops playing...Toshiba support is useless..only online support for vcr's...the faq's don't address this issue..sent an email and told to refer to manual...manual does not address this issue...can you suggest or recommend something?? vcr worked fine until this issue cropped up...thanks for your time...
5 Suggested Answers
  • 883 Answers
SOURCE: Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Posted on Aug 30, 2007
sharcnet
  • 2130 Answers
SOURCE: Toshiba M-752 Video Casette Recorder
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Another possibility is that the tape is caught aroung the spindle guides that pull the tape around the video head. If the tape is caught in the spindles, this will affect playback performance. The heads could be dirty too. Another possibility for poor playback is a slipping idler wheel. The idler wheel is a rubber tire that pivits between the tape sending and pickup reels. It's a key part during playback, fast forward & rewind. The idler tire can also be treated with a re-grip solution or be replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Posted on Jan 15, 2008
  • 736 Answers
SOURCE: wont play tapes
there is a detector inside the machine the makes sure the tape is actually moving from the payoff reel to the takeup real .. if it detects that isnt happening then it shuts down rather than spool tons of tape all over the inside of the machine .. if more than one tape is doing the same thing then your vcr needs service ...often the problem is a rubber wheel that loses traction .. it can be replace or cleaned but dont use alcohol .. that will remove the elastomer in the rubber wheel .. you can use just water or special solvent made for cleaning idler wheels ... even if the unit is new its likely to have been in stock for a long time .. the surface of the wheel can oxidize or sometimes the wheels get hard with age ... if its just surface contamination, you can use a pencil eraser to clean it .. this involves taking the bottom of the player off to get at the wheel ... if the unit is still in warranty then i would return it .. often professional repairs are more than the VCR costs new ..
Posted on Aug 20, 2009
Testimonial: "thank you i was worried that i bought a bad player"
Grubhead
  • 5259 Answers
SOURCE: I have a VCR and while playing an old tape the
The heads are inside the VCR. You can buy from your Local dealer a VHS head cleaning cassette that should solve the problem. Normally I would recommend going inside the VCR to clean it with Servisol Video 40, but in your case I would stick to the tape!
Posted on Sep 14, 2011
Toshiba DVR-670 VHS VCR plays then stops
Something is causing the electronics to think that the mechanism is faulty. It will shut down the system if it thinks that, to prevent tape damage. You need to check for any kind of damage to the mechanism. I know you say you have looked, but check again. If you don't find anything. I would replace the VCR mode switch. You might get away with a spray of Servisol Video 40 on it, but if you can replace it. You will need the service manual for that. As they are tricky to set up.
Jul 04, 2016 | Toshiba Televison & Video
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
LG280W VCR safe mode
hold the power button down for a few seconds or press stop
Jul 23, 2010 | LG MG64 VHS VCR
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Vcr tape plays for a few seconds then powers off
remove cassette mechanisum and clean all the sensor's
Sep 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tape stuck in an Emerson Model EWV401 VCR
take it to someone who has experience in removing stuck VCR tapes or you will be paying a lot more for a new VCR. They won't charge you much....IF they even charge you.
Apr 04, 2008 | Televison & Video
Aug 30, 2007 | Toshiba M655 VHS VCR
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Toshiba W627 VCR Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
