Question about Sony KV-13VM30 13 in. Combo
Tv sound problem
K here is the problem the tv started giving horizentak white lines and the sound goes away . what may the problem be ? thanks alot
0 characters
1 Points
Ther is a white horzontal line in the middle of my tv and i dont hear or see the screen
he white horizontal line with no picture is ususally caused by a failed Flyback transformer in CRT type TV's
repair cost about $200
please rate my help++++Thanks for using FIXYA
Jun 23, 2010 | Combination Televisions
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
Line across the tv no sound no picture
If you look carefully at teh line it should be red, green, and blue close together to appear like a white line. If this is the case, then the vertical circuit has failed. This is often poor solder connections at the vertical IC or a defective IC. Expect a parts cost in the $20 range for this repair.
May 04, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
42 inch toshiba has horizontal white lines when turned on in the morning goes away after 1-2 minutes
This issue is usually caused by some "lazy old" capacitors in the Vertical sweep section or cold solder joints. That is a large TV so it would be worth having an experienced 'old school' tv tech fix it. They can easily find the bad component using Freeze Spray that will reproduce the problem by acting as a cold start. Either way this issue will not damage anything else on your tv and may or may not get worse over time.
Jan 07, 2010 | Toshiba Combination Televisions
White lines at top of screen - can't make go away
You have a problem in the vertical output circuit. Check for bad capacitors around the vertical output IC. The value of these caps are marked on the side of them. Thanks for using fixya. Please take a moment and rate this responce.
Nov 30, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Only has a line through center of screen
Problem started as a simple cold solder joint. Now the connection has either burnt to the point of not making any connection at all, or the vertical output has gone out due to the stress. As far as the dvd player goes. Sounds like the microprocessor is heating up and going bad. Nothing can be done other than replacing the whole unit.Should be able to order it from Toshiba.
Oct 16, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Combination Televisions Logo
Top Sony Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Sony Combination Television Expert? Answer questions, earn points and help others
