Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Converting a GE Profile Gas Range from LP to natural gas
I need the orifices to convert the range from LP to natural gas
  • lswadner Apr 02, 2009
    I have almost the same problem...I want to convert a GE model number JGSP44WEY4WW from LP to NG, but the orfices are not on the stove. Can you tell me the orfices I need to order to do this? Thanks - Larry
  • Miki May 20, 2013
    I have the same problem with a GE Profile range, model #PGB908SEMSS. Was converted to LP and need to convert back to NG now. Can I get part number?
  • 1,543 Answers
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 2 more comments
  • Crgswanson Jun 02, 2012
    Mgr4452bdp gas range, i need to no the pArt numbers for natual gas orifises please
  • Miki May 20, 2013
  • Miki May 25, 2013
    mine is a GE Profile model#PGB908SEMSS
  • Jim Martin
    Jim Martin Nov 16, 2015
    my model number is JDR8895AAS and the natural gas orifices are missing.
Converting Bosch HDI7282U/09 back to natural gas / orifice sizes?
they are set sizes and you need to change the air shrouds as well to get proper burn
this is a job for an accredited gas fitter so call one in and he will
have the correct jets and be able to adjust the air shrouds as well
Nov 10, 2015 | Bosch Kitchen Ranges
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting from lp gas to natural gas
just the orifices will do, the bake and broilerahve an adjustable hood thatwill need to be tightened down as well as an adjustment made to the regulator(needs brass nut flipped from nat. to lp.)
Mar 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,923 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
