Question about Campbell Hausfeld 26 - Gallon Air Compressor
Compressor will not start
Motor buzzes as if it is bound up then trips my 20 amp breaker. Motor appears to turn freely by hand. Compressor starts and turns 1 to 2 revolutions then stops and starts buzzing. This happens with and without air in tank. Please help!
    President:
  • Campbell Hau... Master
  • 1,388 Answers
It is a good sign that the motor turns freely with and without air. That indicates that you have good bearings and that the intank check valve is in good condition. Next you should check the capacitors and the condition of the windings. Some motors have start and run capacitors and others only have run cap. Remove from the circuit and test with meter having cap. test setting. Most shops will test them for free. The cap should test within 95% of stated ( uf ) value. Replace as needed. Finally check that the flyball switch at rear inside of motor is functioning correctly. At rest, switch is at start winding, then a split second after start, it shifts to run winding. Check contacts are not stuck and that switch is working and lastly that the winding are the color of new penny. Good luck.
Posted on Jan 06, 2009
Electric motor buzzing
you need to check for a bad capacitor first which it might not have... then suspect a bad motor.
after research it appears you might have two caps on top of the motor
Dec 28, 2013 | Eagle TT318E-DV
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
FOX 254 MM TABLE SAW E36-529 PRESS START SAW STARTS THEN BLOWS TRIP
Making sure the saw is unplugged ( not just turned off ) and using a pair of heavy gloves, grasp the saw blade carefully and see if it turns freely. If not then dis-connect the drive belt from the saw and try again. If he saw turns easily now and make no grinding noises then it appears your trouble is elsewhere. While the belt is dis-connected try to turn the motor my hand. It should turn smoothly but with a little resistance. If it turns ok then we must look elsewhere again.
Look at the specifications plate on the saw to determine how many amps the saw requires to run and then check the rating of the circuit breaker that trips when you turn on the saw. If the saw requires 15 amps to run and is on a 15 amp circuit then it needs to be relocated to another outlet, preferably one with a 20 or 25 amp breaker.
Mar 13, 2011 | Saws
The Electric motor does not have enough torque to start compressor. It is hooked up to 230V with 40 amp single phase. checked voltage with meter so I know it has enough voltage.
Does it trip the breaker or does the motor just hum and not turn the compressor? The motor may need a start capacitor. Do not keep tryin to start you can burn out the start winding on the motor.
TURN OFF POWER AND LOCK OUT.... try and take the belts off (if it has belts)of the motor and compressor and make sure both turn freely. IF THEY TURN FREELY THERE IS A PROBLEM WITH THE MOTOR. You said voltage, wire size and breakers are the right size.
Hope this helps you with your problem...Jim...please leave a comment
Feb 13, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Electric motor will not start . just grrrrs and trips breaker. was ok 3 days ago. only use compressor occasionally
May or may not have a start capicitor on the motor
Sounds like either the start cap is bad or the motor has seized up
Try turning the motor by hand after removing the drive belt it should turn freely
Mar 30, 2010 | Campbell Hausfeld 13 - Gallon Air...
Compressor won't sstay running and trip breaker
You gave a lot of information, but you didn't say if it worked when free wheeling. If not, I would suspect the inertia switch. If it is working, you should hear it click when the motor is winding down after being shut off, at least when free wheeling. A 20 amp breaker will certainly handle a 15 FLA motor, even on startup. They don't trip at 20 amps exactly, especially on a simple overload. Even at twice the rated amperage, it can take several minutes to trip it. They will trip quickly on a dead short, however, or a severe overload. I doubt the windings are shorted or it either wouldn't work (start windings) or would run at a slower speed with the inertia switch constantly tripping in and out with it coasting while tripped in (i.e., accelerate, coast, accelerate, coast, etc.)
Mar 06, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
A/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
IR T 20 air compressor will not kick on
IS IT THREE PHASE OR SINGLE PHASE? MOTOR TAG WILL SAY PH 1 OR PH 3.DOUBLE BREAKER OR TRIPLE BREAKER WILL ALSO TELL. IS THIS A BRAND NEW INSTALL OR AN EXISTING COMPRESSOR THAT JUST NOW STARTED DOING THIS. SOUNDS LIKE A POWER PROBLEM LIKE A MISSING PHASE OR BLOWN FUSE. REMOVE FUSES WHEN OHM CHECKING - DONT TEST THEM WHILE STILL INSTALLED.
Mar 14, 2009 | Air Tools & Compressors
Air compressor flips breaker before it will start?
Air compressors tend to draw more power as they age, however, will not trip breaker unless some malfunction. Here are some simple tests. Unplug compressor and turn the pump by hand, you may have to remove a cover to do this. It should turn freely; any resistance could be failing bearing (would make noise) unloader/check valve leaking allowing back pressure to pump, or failed start capacitor/start winding. Easy test for checkvalve. With pressure in tank loosen discharge hose at tank and check for air leak. Check valve should hold pressure in tank. Replace as needed. Failed capacitor/s will cause high amp draw. Remove from circuit and test. UF reading should be within 95% of printed rating. Finally, most air compressor motors have two windings, start and run. Power to windings is controlled by flyball switch inside rear of motor. This switch has contacts that can stick in start position and cause high amp draw. Examine windings for signs of overheating. Copper windings generally have color of new penny. Very dark brown windings bad news. Gook luck
Jan 06, 2009 | Air Tools & Compressors
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
439 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
