Question about LG 42LG50 42 in. LCD HDTV
CANT CONNECT MY BOSE COMPANION 3 SPEAKER TO MY 42LG50 LCD TV
I TRIED CONNECTING IT TO THE LCD TV AUDIO OUTPUT JACK IT STILL DIDNT WORK....
  • Anonymous Jan 28, 2009
    same here have seen it done in my local comet will have a look and ask them
  • Anonymous Mar 17, 2014
    I connected a Bose SOLO sound system to the digital audio output. TV speakers developed problem 3-4 days later. Bose system works but cant use tv speakers or stereo speakers. One of the DVI jacks pulled loose when I tried to remove the cable.
I have just brought the bose companion 3 speakers and i connected it to the headphone socket in my tv and it worked.
Hope this helps
Posted on Apr 15, 2009
HI, I am trying to connect my cerwin vega xd3's to my pc (which works fine) and my Samsung LCD TV. I am not getting any sound out of them with the TV on. I have replaced the rca jacks and still...
The "audio jacks" on the rear of your Samsung TV are intended to connect TV audio to an amplifier. Your CV XD3s should be connected to the amplifier output.
Aug 10, 2013 | Cerwin Vega LW10 Subwoofer
I have a Harmon Kardon HK 3370 Stereo Receiver and a Samsung LCD LE40C530F1W. When I connect the stereo Aux jack to the LCD Audio jacks ( red and white rf cables ) I get no sound out via the receiver.
Obviously make sure your stereo mode selector is set to AUX and the volume on the stereo is turned up at least a little when you test it.
If you still have no luck then try increasing the volume on the TV as well. You may have it set so that the level of the audio signal leaving the rear output connectors on the TV varies with the TV volume. That way if your TV volume was turned down or muted when you tested it, then you would not hear anything coming through your stereo.
There should be a setting in the AUDIO OPTIONS menu of your TV where you can switch between a VARIABLE AUDIO OUTPUT and a FIXED AUDIO OUTPUT level.
With the FIXED audio output level, you control the volume of the TV audio coming through the stereo speakers with the stereo remote only.
Otherwise it should work.
Good luck.
Jul 16, 2011 | Harman Kardon HK 3370 Receiver
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Connecting an Acer 6920G to a LCD TV
Unfortunately, DVI doesn't support audio. Your headphone output may work if you have a PC audio input on the TV. However, you might need to change the audio output on the Acer 6290G. It is probably defaulting to using the HDMI audio output.
Go to the Control Panel (click on Start). Select the Hardware and Sounds section. In Sounds, look for Manage Audio Devices. Change the Default Audio Device to a different Audio device (look for Output in the description). Note: you may need to turn off the computer and TV and turn them both on for the headphone jack cable to be identified.
If this doesn't work, check the manual for the TV. It might only have the PC audio connection available for a VGA port. Please add a comment with the TV model, if you need assistance with this step. Make sure that you aren't connecting the headphone out of the 6920G to a headphone out on the TV.
I hope this helps.
Sep 07, 2017 | Acer Aspire 6920-6422 Notebook
We connected the computer to polaroid lcd screen and it doesnt want to turn on can any one help me
l;kl
  1. Use a D-SUB cable to connect the PC’s D-SUB output jack to the LCD TV’s VGA input jack. Use an audio cable to connect the PC’s audio output jacks to LCD TV’s.
  2. Connect all AC power sources, before turning on the power switch of the LCD TV or other connected equipment.
  3. Press the button on the remote to turn on the LCD TV.
  4. Press the Input button on the remote to select COMPUTER.
Sep 11, 2009 | Polaroid 3211TLXB 32 in. LCD Television
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Watching T.V. with speakers
Component 1 on the TV is probably an input, not an audio output. You need to find out if your TV has audio output jacks.
If I'm mistaken, and you are using audio output jacks from the TV, then you just need to press FUNCTION on your remote until the LCD display says "TV/VCR".
Apr 28, 2008 | Sony DAVHDX265 System
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
LG 42LG50 42 in. LCD HDTV Logo
2,466 people viewed this question
Computer Repairing
Computer Repairing
