Question about Hoover HCA351K Bottom Freezer Refrigerator
Freezer will not work due to out side teperature being low
The freezer is in my garage utility room and the temperature is about 5deg
I have moved it back into the main kitchen and it is now working fine.
Is there an Ambiant temp switch to adjust so that I can move it back?
  • 135 Answers
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Posted on Jan 06, 2009
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Ice maker quit working
check the teperature of the freezer compartment . the ice harvest actuates on teperature. and refill with water at the end of harvest cycle.. a lot of times the condensor under your fridge can become plugged with dust and the freezer teperature never achives low enough to harvest ice..good luck
Oct 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped making ice
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
Sep 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ref in door ice not making ice
Sep 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Dispenser
Sep 15, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gs5shaxnb02 Ice maker
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Hoover HCA351K Bottom Freezer Refrigerator Logo
201 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
