Question about Royal 10X Shredder
Royal 10X confetti shredder
Shredding is sluggish. It seems the motor is working really hard to just shred one piece of paper. Also what it does shred doesnt seem to fall down to bin. I have to stop shredding turn off and manually pull the paper from the blades. Any ideas?
  • 35 Answers
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Posted on Feb 23, 2009
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Is it possible to unjam this shredder. It was allowed to get too full and I started eating it's own shredding . I have pulled all of the paper out that I can - but it still won't go.
If you have cleared all jammed paper out of the unit but its dead and wont run then its likely you have blown the PCB inside...replacement parts you can get from Royal at 1-800-524-0799.
Oct 16, 2010 | Royal 10X Shredder
Both sets of shredding gears turn and sensor and auto for both paper and media work. However, the intake function for both paper and media do not. This occurred after extracting paper following and...
Does the machine at least run...even in reverse!!
If it does not then you have likely lost the pcb ...you can contact Royal at 1-800-524-0799 for parts availability and pricing.
Sep 20, 2010 | Royal 160MX Shredder
I have a 10X confetti paper shredder model # PCUA 29054E. When I put the paper in it shredds spuratically. It will shred then stop then continue then stop completely. If I back it up it might continue but...
Lubricate the machine....put shredder oil onto a sheet of paper and shred it...do this a number of times to get the oil down into the cutting blades... x-cut shredders should be oiled regularly.
Mar 18, 2010 | Royal Office Equipment & Supplies
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Royal 10X Shredder Logo
408 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
