Question about Sony Playstation 3 (PS3) Console
PS3 will not start
The power supply failed ( stepping down from 240v - 100v) while i was in a game. So the PS3 powered off instantly, and it will not turn on properly again. After i replaced the step down transformer and plugs everything back in. The red light will still on when i plug it into a new step down(indicationg the power supply in the PS3 is not fried yet?). But when i try to start it up and i could hear the fans firing up, it will put itself into standby in abt 1 secs. And obviosuly failing to eject my disc inside.
    Problem Solver:
  • 7 Answers
Okay, try to turn it on with the sixaxis, but hold the ps button for 5-8 seconds: I think that can reset the PS config settings. or something like that. Also call the support number (800-488-7669) If it's under warranty (which it should be since the system hasn't even been out for a year), I'd suggest trading it in for another one, but keep the hard drive or have them transfer the info, and get them to give you another game. If it stepped-down it may have browned-out, which means it may have fried the chips. It sounded like the PS3 tried to save it by turning off automatically, but if you're having troubles starting the OS, it sounds like it may have spiked before stepping down. Yeah, I'd get another one since it's under warranty. No use ice skating uphill.
Posted on Jun 15, 2007
I received a ryobi 36v battery charger as a present. It was brought in America and has a American plug. Can I use this charger in Australia
Australia has a 230v supply, and the US 110v. The power supply for your charger will indicate what input voltage it can handle. PCs, for example, typically have power supplies that can use anything between 100v and 240v, which means you can take your laptop from country to country without worrying. My Ryobi charger on the other hand says 240v input, so it doesn't have this flexibility - usually it wouldn't need to. If yours says 110v then you'll need a converter for it to function properly in Australia.
Jan 12, 2018 | Ryobi Drills
What is the voltage of transformer of crest audio vs450
Power Supply (factory configured): 100V-240V, 50-60Hz
You should only need a standard power cord (like the one that fits the back of a computer).
CREST AUDIO VS450 Specifications Page 2
Feb 04, 2015 | In Store Used Used Crest Audio Vs450
Replace power supply
Are you sure the power pack has failed? That should be straightforward and fairly cheap. Note carefully the model and type on the present one, then shop around.
  • Power Supply
    Internal 220W (100V-240V)
    Form factor: Internal for slim form factor
  • Total wattage: 220W
  • Nominal input voltage range:
    • 100-127V/6A (50-60Hz)
    • 200-240V/3A (50-60Hz)
  • Dimensions: 200mm x 85mm x 53mm (7.9 x 3.3 x 2.1 inches)
  • This power supply has an LED to indicate a possible failure condition when the LED is off and power is connected.
Feb 20, 2014 | HP Pavilion Slimline s5710f Desktop PC
What is the power supply for aomron blood pressure monitor hem712c
It uses the HEM-ADPT1, which is AC 100v-240v input and DC 6V 1Amp output.
Check Amazon for pricing.
Mar 28, 2013 | Omron Genuine Healthcare 6 Volt Ac Adapter...
PS3 shut down, wont start. HELP!
The power supply module has likely failed. Sorry, you will need a service shop. Attempting to FORCE out the disc can cause EXPENSIVE repairs.
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 100 volts, is it posible to change the power supply t0 220v,
BEFORE READING THIS PLEASE NOTE THAT I DO NOT HAVE A PS3 AND I DON'T KNOW IF THIS WILL WORK. IT HAS WORKED FOR OTHER THINGS FOR ME BEFORE, BUT I CAN'T SAY FOR SURE THAT IT WILL WORK IN THIS CASE.
No, but you can get a 100v power supply and splice you ps3 power supply to it. if you dont know how to splice something, you simply cut both cords, strip the wires, and solder or twine the correct wires together. if the wires are insulated inside the shrink wrap (outer coating of rubber), that makes it even easier. just match the colors.
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
Power supply light LED turns RED.
yes, it came with power brick, but recently due voltage problem my adapter was failed and got it repair and now and facing this problem
Nov 21, 2008 | Microsoft Xbox 360 Console
Can't find a power supply adapter for hp 5400c Scanjet - should be 12VDC ? Wish I knew how to modify to accept a hp 4400c Power Adapter
DO NOT buy anything from Impactcomputers.com !!! Link for HP AC power module goes to this website, they are thieves. Send wrong parts, charge you to ship it back, and charge huge restocking fees. Customer service at this site are expert at lying to you. Google "complaints for Impactcomputers.com" and you will see they have 96 complaints to the better business bureau in just a few months. You will never get the part you need from them, they will rip you off.
Oct 23, 2008 | HP Office Equipment & Supplies
Lap tops
It sounds like what you are looking for is a Step up/Step down converter. I do not know of any laptops that come with a 240v adapter since most things here in the U.S. run on 110v.
Do a search on Google or such for a 240v 100v converter.
May 22, 2008 | Apple MacBook Pro Notebook
Sony Playstation 3 (PS3) Console Logo
437 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
