Question about Canon PIXMA MP470 All-in-One Printer
Color prints when I only want black & white.
When I push BLACK button for black and white copying I get automatically color if what I am printing is in color.
    President:
  • 2,692 Answers
Does this model printer have the capability to print black and white from a color image?
Link to manual below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403#DownloadDetailAct
Posted on Feb 05, 2009
Can not get printer to print in black and white
Hi, May be you printer had been set auto color. To set it manually, go to printer setup in your computer. Select you file you wish to print the click print. On pop up printer set up you should see Canon MP 210 series printer. Then Click properties, you can see now the printer options like media, quality, paper source, color, greysacle and priview. Click greyscale to get monochrome printing.click Ok and Ok again. You should get a black white ( BW) printing result. In addition, to duplicate the file to get hard copies from your printer press Black button before do copying to get non color hard copy.
Dec 07, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
Can't print photo in black and white
Could this be the problem? From the User Guide: "Print Color images in Black and White -- Print your color images in black and white to save the ink in your color ink cartridge.
NOTE: You cannot select this setting if you have selected Color Cartridge for all Black Printing"
Dec 23, 2009 | Dell 962 Photo All-In-One InkJet Printer
How do I set my 5550n printer to print only black and white copies and color on demand?
If you go into control panel then go printer options you should see your printer icon. Right click on it and go printer preferences or printer properties and I think there is a colour tab where you can set it to just back and white
Sep 22, 2009 | HP LaserJet 5550n Printer
My printer copy's in color but prints photos in black and white,
Check your settings for your printer software program, change it to black and white, and then you will need to change it back to color, if you want to print in color.
Aug 10, 2009 | Office Equipment & Supplies
Cant print black or do black and white copies
He's not saying that the black cartridge won't print (which would warrant cleaning the heads, or messing with the cartridges) -- I have the same problem that MarkDan is having as well... no matter what you select as the output from any "Print" dialog window, the HP 21xx and 12xx series printers _always_ print in full color. You can choose Black and White, Greyscale, Color -- doesn't matter what you choose in the dialog boxes, it utterly ignores you, and will always print in color.
I have no idea why it does this, but it's eating a _ton_ of color ink for no good reason. I have searched all over the Web and on HP's site, but solution has been found.
Jul 30, 2008 | HP PSC 1210 All-In-One InkJet Printer
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Prints only in black and white
Windows 2000 / XP:
Go to Start, Settings, Printers. (Windows XP: Start, Control Panel, Printers and Faxes).
Right click on the printer icon and select Properties.
Click Printing Preferences.
Click on the Quality/Copies tab.
un check mark Print Color images in black and white.
Click Apply and then OK.
This start ur printer to printer to print in colour
Dec 21, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon PIXMA MP470 All-in-One Printer Logo
325 people viewed this question
old marine
old marine
