Question about Lexmark X125 All-In-One InkJet Printer
Lexmark X125 not printing at all.
The led display reads COVER OPEN/CLOSE COVER. I just put a new ink cartridge in and now it says. COVER OPEN/CHANGE CARTRIDGE! UGH. Anyway I have uninstalled the program, reinstalled it, tried printing from notepad. Disconnected the USB and the main plug while turning the computer off. NOTHING is working. It just keeps coming up that there is an error everytime I try to print anything. I think I even downloaded a new driver but that didn't work either unless I did it wrong? HELP
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
I have a Lexmark X125 printer. I just bought new ink cartridges because I ran out of ink. I followed the directions on the printer to install the ink cartridges and the printer keeps flashing the words...
Remove the cartridges and close the lid. Allow the system to try to calibrate and complain. Open the lid. Check the cartridge bottoms to make sure you removed the plastic cover on the jet heads.
Replace the cartridges and make sure they clip. Close the lid to finish.
if this does not solve it. Remove the cartridges and then unplug the unit from the power. hold the power button down for 10 seconds then give 20 seconds more. this will clear all power. Place the new cartridges in and close the lid. power the unit on and test for success
Feb 14, 2010 | Computers & Internet
How do you change ink
To Change the ink Cartridge please follow the instructions as under:
  1. Turn on your computer and open the front cover of your printer.
  2. The Cartridges will automatically come in center.
  3. Pull up the holder lid and carefully remove the print cartridge on a 60 degree angle.
  4. Press the ink cartridges into the slots and listen for a clicking noise after the insertion
  5. Remove the tape from your new print cartridge and carefully put it in on a 60 degree angle, snap the lid back in place. close the printer.
  6. Open the printer software in your computer, click the tab maintenance and click install a new cartridge and click the number. Print an alignment page.That's it !
Thank you for using Fixya
Oct 08, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark x125 system error after installing new inks
All cartridge installation and level reporting is done through the printer itself, not the software. You should ensure the X125 has the cartridges installed in stand alone mode first. To do so, open the lid and remove the cartridges. Then unplug the power cord for one minute. Reinsert the cartridges, connect the power cord and close the lid. When the lid is closed, the display will ask you if "New" or "Old" cartridges were installed. If new, align the cartridges, if asked to do so. If this still presents you with a "Change Cartridge" message or something similar, please try a different cartridge.
Sep 30, 2009 | Lexmark X125 All-In-One InkJet Printer
Installing ink cartridge in Lexmark X125
The front panel is hinged at the bottom so grab the top and pull towards you.  Under that is a protective cover, the one with the 2 paper guides.  towards the bottom of that there is a hole in the middle.  Put your thumb in it and lift the cover up.  Your carrier for the cartridge is under that.  Please Rate!
http://www.lexmark.com/publications/eng/x125/index.html
That link will give you the manual..just in case you need it.
Mar 11, 2009 | Lexmark X125 All-In-One InkJet Printer
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
The scanner cover is closed, however I get an error message saying it's open. The unit will not print, copy or scan
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
Jul 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
