Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
The stand by timer blinks continuously
The T V just shut down while we were watching it. The stand by timer light continuously blinks when turned on, but nothing else happnes. We wrote of the problem here last night and was advised to inplug the TV for 4 hours. I unplugged it overnight and plugged it in this morning, but I am having the same problem. Thanks
  • 4,234 Answers
Unpluggnig the set will reset some things, but not an error code. The 4 blinks usually means a lack of vertical deflection. If you can solder, you should be able to fix this yourself. Be warned however that there are dangerous high voltages inside the set even when unplugged.
That being said, try locating the vertical IC which will be a small flat IC attached to a heatsink that will be marked LA7837 or something similar. Try resoldering the pins on that IC first. If that failes to resolve the problem, replace the IC and post your results here. There may be other components that need to be replaced, but they will show up as other symptoms once the IC is replaced.
Dan
Posted on Jan 06, 2009
Sony KV-20FS12 shuts off after being turned on, stand by/time light blinks
the blinking is actually an error code. watch the blinking closely and you will see it blink a number of times pause briefly then blink the same number of blinks over and over. If you let me know the number of blinks I can tell you why the set isnt powering up.
Aug 07, 2012 | Sony KV-27V42 27" TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
Feb 18, 2009 | Sony KV-27V42 27" TV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
The screen stays black when the power is turned on. the stand by/timer ligt blinks
There is a high voltage, and or scan failure. This can be the flyback assembly, and or other support components. If the CRT is defective, it can cause this type of shut-down.
The cost for servicing this would be fairly expensive. It would be best to start shopping for a new set.
Jerry G.
Oct 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
