Question about Xerox 5500/DT Laser Printer
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Paper did not jam in fuser unit,only stops at that point.I replaced the fuser unit and problem still shows up. Door E has been removed and problem still does not clear up.About half of paper has print on it .
    President:
  • 2,072 Answers
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Posted on Jan 06, 2009
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
SHOWS PAPER JAM BUT THERE IS NO JAM.
KIT EXIT SENSOR (Fuser Exit Sensor Kit) part no. 015K60900
May 05, 2010 | Xerox Phaser 5550v_dtm 50ppm Laser 256mb...
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox Phaser 7300
Check in side the fuser unit there are two latches to release it and the unit comes out as one. check in there also you may have a paper feeding issue try to use the MPT as the paper sourse.
Sep 26, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
May 19, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
May 06, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Apr 05, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox 5500/DT Laser Printer Logo
625 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
